Will my CX dizzy fit into my d16y8 head? I was told I could?
I heard any sohc dizzy will fit any other sohc as long as the obds are the same. Some of the holes wont line up, some might need modification. I used a d15b7 dizzy on a d16z6 head for a while but i had to slot one of the holes and and tightened it down using washers to hold it in place because only the top hole would line up and the others dont line up with each other. Just spend the extra money to get the right dizzy so you ahve a wider and better range of adjusting you timing correctly.
well the obd is diff, and the weird thing is that the dizzy mounted on perfect and also that therer is alot of room for timing to adjust. sooo yeah. thanks for the reply.
mark
mark
Im using an EX dizzy on my DX motor aka 97d16y7. Its fully retarded to get back to the stock y7 spec though. No advance needed, hehe
hey, I have a 98dx with a d16y7 and i just bought a z6 head, will the y7 dizzy mount to this? if not, what kind of mods do i have to do?
and i am wondering which timing belt i need?
i also bought a p2p ecu and y8 intake mani, my mini me project is starting soon.
thanks
thanks
Didnt fit when i tried to use a cx dizzy on my z6 motor...the bolts dont fit right...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 »</TD></TR><TR><TD CLASS="quote">Didnt fit when i tried to use a cx dizzy on my z6 motor...the bolts dont fit right...</TD></TR></TABLE>
so what did you do? did you use a z6 dizzy? how did u wire it?
so update:
put on the cx dizzy into the d16 and wow! bad idle, 02 wasnt hooked up but still, Im not to experianced in retarding the dizzy but still made the barking kind of idle no matter which way I put on the dizzy, now Im gonna bo buy a LS 96 to 98 harness and should fix my problem, I have to put back my d16 obd2 dizzy to run the LS harness.
thats because the z6 has a different bolt pattern than all the other d series motors.
tangerinebeast
Mar 24, 2011 04:19 PM
