Check out my plugs. Boosted GSR @10 psi
Old Mar 5, 2004 | 07:32 PM
FastNFurious
Guest
Posts: n/a
Default Check out my plugs. Boosted GSR @10 psi
Hey, I'm working on tuning my car with an innovative and it's a pain in the *** because I can't get the RPM's working. I running the VAFC hack with an MSD BTM retarding .5 per psi. I'm running 92 octane, some toulene, and 9:1 compression. And I think my AFR is about 12-13 and from just looking at my AFR the ****** thing shoots up to about 14.5 in some places like the 6k rpm.
Well anyways, if I'm endangering my motor is will show up on my plugs right? I don't hear any pinging and my plugs seem ok(they aren't white).... Any comments??
Old Mar 5, 2004 | 07:40 PM
safe driver's Avatar
no signs of detonation but if you can take a better pic of the area around the electron (the soot covered ring). also look for silverish-white specks in that area for signs of detonation
Old Mar 5, 2004 | 07:51 PM
turbo_ef9's Avatar
Default Re: (safe driver)
they look okay..
Old Mar 5, 2004 | 08:25 PM
lazerus's Avatar
Default Re: (eli_vang)
it doesent have to detonate to blow. get someone else to drive while you tune or vice versa.
93supercoupe
12
Apr 25, 2011 09:06 PM
pip9
Aug 18, 2004 02:38 PM
TurboBumblBee
May 25, 2004 10:15 AM
Nate B
Feb 10, 2003 08:26 PM
