eagle rods with arp 2000 rod bolts
Old Mar 5, 2004 | 03:56 PM
Blanket Jackson's Avatar
Default eagle rods with arp 2000 rod bolts
i just got a set of eagle rods with the arp 2000 rod bolts and i was installing them today and i was torque them down and i got to 40 lbs and two of them broke. they are ment to go to 75 lbs i followed the install sheet and they still broke is that a common thing with arp bolts or did i just get some bad bolts
Old Mar 5, 2004 | 04:07 PM
DavidR's Avatar
Default Re: eagle rods with arp 2000 rod bolts (HONDAofPOKY)
Rod bolts are 28ft/lbs.
Old Mar 5, 2004 | 04:18 PM
Default Re: eagle rods with arp 2000 rod bolts (DavidR)
the sheet they sent me said arp 2000 75 lbs
Old Mar 5, 2004 | 11:53 PM
aeolus's Avatar
the sheet i got with my rods said 28 ft lbs. also.but i used a rod bolt stretch gauge in conjunction with my torque wrench.i come to find out not all the rod bolts will torque down the same.
Old Mar 6, 2004 | 11:07 AM
DonF's Avatar
Default Re: eagle rods with arp 2000 rod bolts (aeolus)
The sheet, that is in front of me says 7/16 bolt 75 ft.lbs.,3/8 bolt 43 ft.lbs, 5/16 bolt 28 ft. lbs. what one do you think you have ?
Old Mar 6, 2004 | 02:35 PM
carcala's Avatar
should be 28 ft. lbs. unless u've upgraded them.
Old Mar 6, 2004 | 02:43 PM
DonF's Avatar
Default Re: eagle rods with arp 2000 rod bolts (carcala)
Upgraded say CARR or 625, not ARP2000 that are 28 for 5/16 bolts.
Old Mar 6, 2004 | 05:08 PM
non-VTEC's Avatar
i would like to see this spec sheet that you got with your eagle rods.......cuz I'm looking at mine and it says 28ft/lbs with moly.
3/8" is the 12 point socket you use to tighten the bolts with but the actual bolt/shaft size is 5/16".....so the correct spec is 28ft/lbs with moly lube.
order yourself another set of ARP 2000 rod bolts for those rods and hope to god you didn't mess up the threads......
Old Mar 6, 2004 | 09:09 PM
aeolus's Avatar
Default Re: eagle rods with arp 2000 rod bolts (non-VTEC)
once you get new bolts,id have the big ends checked again for roundness.torquing down those rod bolts like that could have made the bores out of round a little.
Old Aug 16, 2004 | 05:06 AM
eRACING's Avatar
Default Re: eagle rods with arp 2000 rod bolts (DonF)
Old Aug 16, 2004 | 07:25 AM
Eddiebx's Avatar
they meant the thread size, not the head size, when measuring the head, so you have a 5/16" bolt
but honestly, commmon sense would tell you not to try and torque such a tiny bolt to 75lbs,
Slo96ex
Feb 18, 2008 03:07 PM
pentaq
Jun 21, 2006 08:33 AM
EnzoSpeed
Sep 22, 2005 03:20 PM
DRAGLS
Feb 5, 2004 01:22 PM
Scott - 93HB Si
Jul 30, 2003 05:19 AM
