bearings on differential
Old Mar 5, 2004 | 02:02 PM
mattssi's Avatar
Default bearings on differential
How hard is it to take these off? This is a 99 si tranny!
Old Mar 5, 2004 | 02:09 PM
mattssi's Avatar
Default Re: bearings on differential (mattssi)
bump
Old Mar 5, 2004 | 02:13 PM
2lua's Avatar
you need a bearing press to seperate it out. it look like a cradle it go between the diff case and the bearing. imo just take it to the a machine shop and let them do it for you.
Old Mar 5, 2004 | 02:26 PM
mattssi's Avatar
Default Re: bearings on differential (2lua)
I did, but i was hoping they would be able to get the bearings off without hurting them, so i could re-use them, or is that bad?
Old Mar 5, 2004 | 02:30 PM
pro1342's Avatar
If you remove them........replace them with new ones. The bearing splitter and/or puller is going to damage them.
Old Mar 5, 2004 | 02:51 PM
2lua's Avatar
Default Re: (pro1342)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro1342 &raquo;</TD></TR><TR><TD CLASS="quote">If you remove them........replace them with new ones. The bearing splitter and/or puller is going to damage them.</TD></TR></TABLE>
Old Mar 5, 2004 | 03:20 PM
mattssi's Avatar
Would you suggest getting honda replacements? There is a bearing manufacturer close by, I bet i could get a better deal there, or should I just pay for the overpriced honda ones?
Old Mar 6, 2004 | 05:02 AM
pro1342's Avatar
I would go with the OEM bearings.
Nhilcrest
Apr 10, 2011 12:23 PM
EG6_DREAMS
Sep 13, 2007 08:55 PM
93h22a1vtec
Oct 15, 2006 07:19 AM
Dublocivic
Jan 16, 2006 06:23 PM
cueballsi
Feb 18, 2005 06:21 PM
