o2 simulators: Work? or BS?
Old Mar 5, 2004 | 01:30 PM
jdmh22ek9's Avatar
Default o2 simulators: Work? or BS?
I just finished a swap in my EK.(obd2b). Since I live in Washington, our emissions is extremely easy to pass and I would like to run a straight exhaust pipe to my header bypassing the cat.
So..
A good seller that I know of promises me that I wont through a CEL with his o2 simulator. ($69)
Good ? Bad ? Do they work? Other options
Thanks guys
Old Mar 5, 2004 | 02:06 PM
mooseknuckle's Avatar
Default Re: o2 simulators: Work? or BS? (jdmh22ek9)
some kid i know used one on his dx turbo, and it didnt run a cel. So i guess it works.
Old Mar 5, 2004 | 02:32 PM
2lua's Avatar
to me i think you shoud use your o2 sensor, then your ecu will know when to lean, or add more fuel to your motor. the other hand if you use the o2 simulator it try to trick the ecu that the exhaust is ok all the time, therefore; the ecu is in limp mode.
Old Mar 5, 2004 | 02:39 PM
Draco's Avatar
Just get a high flow cat. They provide almost no restriction, and you can keep from polluting. You also won;t have to worry about adverse effects from running that simulator thing. Closed loop ECU operation is gooood.
Old Mar 5, 2004 | 02:52 PM
boostedcivicsir's Avatar
Mr. Badwrench
we have one on an IS300 with cat delete headders and no probs there. i have put 3 on spec v's with no issues either.
Old Mar 5, 2004 | 05:10 PM
jdmh22ek9's Avatar
Default Re: o2 simulators: Work? or BS? (boostedcivicsir)
I was told that even with a high flow cat your car will still throw a CEL. Is this true?
Old Mar 6, 2004 | 03:29 AM
Mr. Badwrench
as long as the cat is doing its job, it should not throw a code. that sensor is not like the front. it should be a stable signal. unlike thr front that sweeps up and down. if the cat is burning all it needs to, it should be ok.
Old Mar 6, 2004 | 06:23 AM
99blusi's Avatar
I had a Ziptech o2 sim for about 8 monghs and never had a cel. Kteller.com sells them an *** load cheaper than the $69.....
Bleakened
21
Jun 25, 2014 05:48 PM
JDMBoosted
Jul 18, 2010 06:35 PM
HONDA RR
Sep 16, 2005 03:53 PM
ITR981002
Aug 26, 2003 07:14 PM
moike
Jun 24, 2003 04:27 AM
