P0420 and no cat
P0420 and no cat
I haven't had a catalytic converter in over 2 years and just now I get a code saying it's broken/inefficient.
I reset the ECU and it hasn't come back since. Anybody know why it came about?
I have a 98 DX Hatch with a stock Y7 but aftermarket full exhaust.
Re: P0420 and no cat
Also, how could I check the O2's for proper function? I have a bluetooth scanner and app on my tablet for it. What do I look for? Voltage ranges?
The Grumpiest
WHy would it read as a bad O2? The second sensor looks for the efficiency of the cat that you don't have. How you weren't throwing codes earlier I don't know. What brand O2 sensors?
Cool Cool Island Breezes. BOY-EE
The 2nd O2 sensor's job is to check if the cat is working. Yours is not present and the secondary O2 sensor can see that. So...not a bad sensor. The sensor is doing its job.
You can either reinstall a cat (yeah...I know you're not gonna do that), or install a spark plug defouler on your 2nd O2 sensor. The 2nd O2. The 2nd one. The one downstream.
I said 2nd one because if you do the defouler trick to the primary O2 sensor, you'll have a lot more issues.
Google "spark plug defouler O2 sensor" or something.
While this^ is currently true, it hasn't been true for 8 months, if I understood what the OP has said.
It's a monitor. The Y7 probably runs clean enough that the waveform the secondary sensor sees during closed loop is USUALLY within a tolerance and the light never went on. Rare...but not unheard of on extremely low emissions engines.
Things that could have changed:
-new O2 sensor is of a different brand with different acceptable internal resistance standards during manufacturing.
-new O2 sensor is more sensitive/less fouled than the old one.
-driving habits changed
-engine condition changed.
-an exhaust leak prior to the 2nd O2 sensor is now sealed.
It was probably by fluke or some stroke of luck that the light didn't come on before. Either way...if he was lucky before, you can't blame the new sensor for actually doing its job.
The sensor may still be faulty (if the voltage reading is always high), but you'd be groping in the dark for that theory at this point since the cat is NOT there...the O2 is technically doing its job.
Help us out here OP. 8 months no CEL and no P0420, right? Was a recent change made? Was this CEL/code associated with some work done or some road event?
Where are the 2 sensors installed into the exhaust system?
I have the upstream and downstream O2's installed in proper places. First one is on the 3rd cylinder header pipe I believe and 2nd one is down under just past the test pipe (cat delete). Been this way since I got the exhaust and installed the O2's. No CEL till now.
Also, still no CEL came back yet as of me writing this post.
The primary O2 sensor should be located where all the header pipes converge. Your O2 sensor may be primarily monitoring exhaust from one cylinder.
He has an aftermarket header. Its not uncommon to see the primary sensor in only on tube of the header on a D series.
If only Honda would have made the primary O2 sensor sit in the collector like they do on a B series....
The primary can't throw a cat efficiency CEL anyway.
