problem with NRG battery
Old Mar 5, 2004 | 12:55 PM
JDMvtecDRAGSTA's Avatar
Default problem with NRG battery
okay well i got the NRG battery today from heeltoeauto
i put it in my car, tried starting it and it wouldnt start.
afterwards, i tried to jumpstart it, still doesnt work
i took it to get it tested, and the test said 11volts (or amps i dont know)
doesnt the car battery need 12 volts/amps to start the car???
any suggestions, is the battery bad?
thanks in advance
Old Mar 5, 2004 | 01:21 PM
Default Re: problem with NRG battery (JDMalphaSKATER)
nevermind i got it working
Old Mar 5, 2004 | 01:27 PM
snoochtodanooch's Avatar
bad connection huh. the posts sometimes are a little too small and need extra tightening. THat battery rocks.
Old Mar 5, 2004 | 03:10 PM
51mpgcivic91's Avatar
A battery at full charge should be 12.6 volts. With the car running you should see about 14 volts on the meter
Old Mar 5, 2004 | 05:35 PM
SiR831's Avatar
what was wrong?
Old Mar 5, 2004 | 08:07 PM
Default Re: problem with NRG battery (SiR831)
he probably just had a bad connection, those batts rock
Old Mar 5, 2004 | 08:25 PM
HATCHingMN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR831 &raquo;</TD></TR><TR><TD CLASS="quote">what was wrong?</TD></TR></TABLE>
he install it backward J/k hehe..
Old Mar 5, 2004 | 10:31 PM
i guess it just needed a long recharge, the battery was pretty drained
Old Mar 5, 2004 | 10:39 PM
Usdm1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMalphaSKATER &raquo;</TD></TR><TR><TD CLASS="quote">
i guess it just needed a long recharge, the battery was pretty drained</TD></TR></TABLE>
If the people that sold you that battery have more instock and let them all sit with out charging em like that. will cause the battery to sulfate and grow crystals on the plates, which inturns makes the battery bad. It also shortens the life of the battery by having it sit in a discharged state.
Old Mar 5, 2004 | 11:03 PM
spnfed's Avatar
How do you like it?
Old Mar 6, 2004 | 05:29 AM
Default Re: problem with NRG battery (spnfed)
its deep cycle, it will hold a charge for much longer and it will not lose a charge as quickly.
Old Mar 6, 2004 | 09:16 AM
Usdm1's Avatar
Default Re: problem with NRG battery (snoochtodanooch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">its deep cycle, it will hold a charge for much longer and it will not lose a charge as quickly. </TD></TR></TABLE>
yeah, but 11volts is really low. I work in a radiator and battery warehouse. we have to go and charge all of our batterys if they drop under 12.3volts.
Deepcycles have more reserve capacity so, it can hold its charge longer, but it will still sulfate just like any other battery. That battery must have been sitting at least 5months to a year.
Old Mar 7, 2004 | 05:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spnfed &raquo;</TD></TR><TR><TD CLASS="quote">How do you like it?</TD></TR></TABLE>
its cool so far
Old Mar 7, 2004 | 10:38 PM
spnfed's Avatar
Sweet I'll keep that bettery in mind.
b20hondacivic
Feb 5, 2013 07:50 PM
W O T
May 8, 2007 11:38 PM
dude wheres my car
Audio / Security / Video
Jul 16, 2004 07:16 AM
vizsual00
Aug 11, 2003 11:48 AM
RTW DC2R
Mar 5, 2003 02:12 AM
