how would you know if you have a bent valve?
Old Mar 4, 2004 | 05:20 PM
superturboprelude's Avatar
Default how would you know if you have a bent valve?
Old Mar 4, 2004 | 05:41 PM
Revi's Avatar
Default Re: how would you know if you have a bent valve? (superjunprelude)
Ruff idle and loss in power. But the most accurate way to find out:
Compression Test
Old Mar 4, 2004 | 08:44 PM
john d
Guest
Posts: n/a
Default Re: how would you know if you have a bent valve? (Revi-Ra)
compression test
Old Mar 5, 2004 | 12:33 AM
UA6 BALLER STATUS's Avatar
Default Re: how would you know if you have a bent valve? (john d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">compression test </TD></TR></TABLE>
One of the best ways to tell.
Old Mar 5, 2004 | 12:49 AM
@ries's Avatar
Besides a compression check you can also do a leak down test. Try to listen for air to be leaking out the exhaust (bent exhaust valves) or hold the throttle wide open and listen if air is escaping through the intake (bent intake valves).
89civichb
11
Mar 10, 2009 08:26 AM
torqueless
Oct 5, 2006 03:19 AM
SwiftTypeR
May 10, 2005 05:22 PM
RGoose18
May 21, 2004 10:13 AM
Goldfingiz
Dec 13, 2002 10:30 PM
