Stock vs Forged Pistons
I'm planning on building up my b18c1. Compression wise, I would prefer to be 11.5-11.8:1. Initially, I was planning on purchasing IB Spec Wisecos/Eagle Rods. But why not just go with stock pistons? For example, JDM ITRs or JDM p30s. I believe those would yield mid 11 compression.
What is the benefit of going with a forged aftermarket 11.5:1 piston as opposed to a stock cast jdm itr piston?
GSR rods should be ok with upgraded ARP bolts for 9000rpm?
Stock rods are lighter than Eagles right? Would anyone happen to know how much of a difference?
I'm wondering too, bump this back to the top. I figured since forged pistons are tougher they'd last longer. No? Do they wear out the sleeves? If you were to go with heavy duty aftermarket sleeves would that make them more long-term?
having slap will depend on if you are going with high silicone or low silicone forged pistons. High silicone are brittle compared to low silc. but, still tougher and expand less than stock which is why you can run tighter clearences with them. Low silicone are the least brittleand the strongest but expand alot [usually just used for pulled track cars] which is why thet are run at loose clearences.
I was talking to an engine builder and he recommended against going forged. They might be stronger, but they are softer which makes them wear faster.
Strength and durability don't always go together...in fact, it seems to me that it's quite the opposite when it comes to car parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spirit7627 »</TD></TR><TR><TD CLASS="quote">having slap will depend on if you are going with high silicone or low silicone forged pistons. High silicone are brittle compared to low silc. but, still tougher and expand less than stock which is why you can run tighter clearences with them. Low silicone are the least brittleand the strongest but expand alot [usually just used for pulled track cars] which is why thet are run at loose clearences.</TD></TR></TABLE>
The problem here is that high silicon forged pistons are somewhat tough to find. For whatever reason, the aftermarket definitely favors low silicon pistons.
Snowman3645
Nov 18, 2013 12:04 AM
ShawnR
Jan 5, 2006 03:35 PM
ic108
Feb 7, 2002 09:46 PM
