Has anyone had this brake problem before?
Old Mar 4, 2004 | 03:52 AM
nitroice40's Avatar
Default Has anyone had this brake problem before?
I have a 99 Integra, quite often I will be driving and both ft brake calipers will drag and the brake petal will get hard. I took the right side caliper off and it looked good, I compressed it and it went in fine. I took the left side off and it looked good but when I went to compress it in it would not go in. If I opened the bleader it would go in fine. I took the piston out of the caliper and everything looked ok. Both slide pins are fine.
My friend said that it could still be the caliper, I think its the master cylinder. I just dont want to buy the parts I dont need if I dont have to.
Has anyone had experience with this before.
Modified by nitroice40 at 8:03 AM 3/4/2004
Old Mar 4, 2004 | 05:49 AM
Ryan3933's Avatar
Default Re: Has anyone had this brake problem before? (nitroice40)
When you took the piston out of the caliper, did you clean it and replace the piston seal and boot? Also, did you replace the boots for the caliper pins as well as clean and re-grease them? These parts are very cheap compared to a re-man caliper and a new master cylinder.
I had the same problem on my '90 Teg except with the rear calipers. Rebuilt them and no problems since.
Old Mar 4, 2004 | 01:43 PM
nitroice40's Avatar
Default Re: Has anyone had this brake problem before? (Ryan3933)
I cleaned it all, the piston and rubber looked brand new.
I regreased all the pins also.
I bought a caliper its sitting in the car with a fresh can of Dot3. I just dont want to put it in and find out its not the problem.
Old Mar 5, 2004 | 04:03 AM
JimBlake's Avatar
It sounds like a brake hose. The inside wall comes away from its reinforcement & collapses. That's like pinching the hose shut...
I think I saw this on another board too. Wazzat you??
OogalyDoogaly
Honda Motorcycles
Apr 6, 2009 01:28 PM
jaideep_asokan
Jun 13, 2007 08:02 AM
Aber
Mar 12, 2004 02:51 PM
nitroice40
Mar 5, 2004 12:45 PM
david90
Dec 8, 2003 05:21 AM
