What's wrong?
Old Mar 3, 2004 | 02:10 PM
KEVlN's Avatar
New User
Default What's wrong?
My friend has a 91 integra. She says she is having problems with her idle. The idle is fine right at first once the car is started, but once it warms up the car just wants to die. Happens more if she is consistently starting and turning off the car(i.e. running erans). Is it a vacuum leak?
Old Mar 4, 2004 | 04:40 AM
KEVlN's Avatar
New User
Default Re: What's wrong? (KEVlN)
Should I start by trying this first?
Intake manifold - clean with carbon build up cleaner
Throttle body - clean with carbon build up cleaner
Clean air filter
Clean IAVC
Change oil
Replace PCV valve
Index your spark plugs
Fuel injector cleaner
New Fuel filter
Anything else I can do if all this doesn't work?
TIA
Old Mar 4, 2004 | 04:53 AM
stasi's Avatar
Yeah, I'd recommend a tune-up unless she's had one recently.
Have you checked out SeaFoam for the carobn buildup? Take a
look at this thread: https://honda-tech.com/zerothread?id=755765
Old Mar 4, 2004 | 04:57 AM
IntEGNYC's Avatar
Default Re: What's wrong? (stasi)
considering its a 91, there's no tell ing how well it was broken in and maintained. engines built back then needed a better breakin than the ones made today.
Like the pervious poster mentions, might be time to do a tune up. perhaps a compression test as well for leaks in the seals.
Old Mar 4, 2004 | 05:17 AM
Ryan3933's Avatar
Default Re: What's wrong? (IntEGNYC)
When exactly does the car stop running? For example, do you mean if the car is up to operating temperature and she goes to get gas, turns off the car, pumps the gas, then goes to start the car again. Does the car start fine but then dies a few seconds after that?
Old Mar 4, 2004 | 06:11 AM
Creep's Avatar
Default Re: What's wrong? (Ryan3933)
dizzy cap and rotor could be added to that list.
Any vacuum leaks?
Had the idle ever been adjusted?
Old Mar 4, 2004 | 06:58 AM
Ryan3933's Avatar
Default Re: What's wrong? (Creep)
Add a new main fuel relay to that list.
Also, since it's a '91, you might want to check the ignition key cylinder mechanism. They're known to go bad and the car will just die while it's running perfectly otherwise.
Old Mar 4, 2004 | 08:02 AM
FlaN.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Creep &raquo;</TD></TR><TR><TD CLASS="quote"> dizzy cap and rotor could be added to that list.
Any vacuum leaks?
Had the idle ever been adjusted?</TD></TR></TABLE>
yep check for vacuum leaks and adjust your idle before you go and spend money. I had that problem with my old 92 LS, turned out to be the idle was too low
Old Mar 4, 2004 | 07:11 PM
KEVlN's Avatar
New User
Default Re: What's wrong? (theJUMPoff)
hey thanks everyone. i'll see if i can figure it out. thanks again.
Old Mar 4, 2004 | 07:26 PM
Creep's Avatar
Did you adjust your idle and see?
Old Mar 5, 2004 | 05:50 AM
KEVlN's Avatar
New User
i'm going to adjust it sometime next week. i'll let you know if that fixes the problem. if that doesn't work, i will start going down the list.
aquafresh93
Apr 14, 2010 01:30 PM
dividedas1
Mar 16, 2009 08:13 AM
EL Vap133
Sep 16, 2008 05:45 AM
tvu
Apr 10, 2007 07:25 PM
blackdelslo
Jan 17, 2005 10:32 PM
