Spark Plug Cover Problem
Old Mar 4, 2004 | 03:41 AM
compwc18's Avatar
Default Spark Plug Cover Problem
After swapping a JDM B16 into my car, I noticed that when I put my CF Spark Plug Cover on, that I was only able to use 2 bolts to bolt it down. Is there any way I can pull the other 2 bolt up or make it so I can use all 4? I purchased a Brand new JDM ITR Valve Cover when I did my swap, and where the 2 holes are, its leaking a little oil and getting on the valve cover? What do I do?
Old Mar 4, 2004 | 07:24 PM
compwc18's Avatar
Default Re: Spark Plug Cover Problem (compwc18)
please help.....
Old Mar 4, 2004 | 08:12 PM
spnfed's Avatar
For the oil leak, are you missing an\ grommet?
Old Mar 5, 2004 | 03:26 AM
compwc18's Avatar
Default Re: Spark Plug Cover Problem (spnfed)
is it one of those little black pieces that go on the studs to put the bolts on?
Old Mar 5, 2004 | 10:38 PM
spnfed's Avatar
Ya the little rubber gasket with the washer,(grommet)
The part number for that thing is-90442-P30-000
Old Mar 6, 2004 | 03:33 AM
compwc18's Avatar
well i do have them, but there are no washers with it?
Old Mar 7, 2004 | 10:42 PM
spnfed's Avatar
The washer should be part of the rubber grommet.
Old Mar 7, 2004 | 11:51 PM
anothersickhatch's Avatar
if those dont work, it never hurts to use a little gasket maker...that stuff works wonders.
Luke_CD5
May 11, 2015 07:25 AM
EM2_PLo
Feb 13, 2010 01:29 PM
b16bri
Mar 9, 2008 09:30 AM
civicxspower
Jun 5, 2005 04:12 PM
xintegr
Mar 18, 2005 08:00 AM
