Labor cost on strut/shock replacement
Old Mar 3, 2004 | 06:48 PM
bwdc2's Avatar
Default Labor cost on strut/shock replacement
I just installed a set of koni yellows and they are way too low(I had the perches on the lowest setting), so I'll need to get a shop to pull them out and reset the perches. How much do you guys usually pay for labor on getting shocks/struts replaced? The shop quoted me $120 to remove/reinstall the shocks and struts, am I getting ripped off? thanks
Old Mar 3, 2004 | 06:54 PM
Kendall's Avatar
If I were in NY, I'd do it for $50. Hell, I'd probably do it for less. It's very easy and anyone with the proper tools can do it. I can change mine in less than an hour and an experienced shop should be able to change them in about the same amount of time. $120 for one our of labor is rediculous. Just find an experienced Honda-Tech member and they'll probably do it for you for almost nothing.
Old Mar 3, 2004 | 08:37 PM
bwdc2's Avatar
Default Re: (Kendall)
Damn...I thought $120 was a bit high....anyone have any good shops in the New York (Queens) area that could do it cheaper?
Old Mar 3, 2004 | 08:49 PM
typeRSXS's Avatar
don't pay more then $80 from a shop.
Old Mar 3, 2004 | 08:51 PM
SweetChin's Avatar
if i were you i would just do it myself... its really not hard to do... pretty much all you need is a jack, 14&17mm wrenches and/or sockets and some size allen key
Old Mar 3, 2004 | 09:10 PM
bwdc2's Avatar
Default Re: (SweetChin)
I remember reading that a spring compressor is also needed.....is that a standard tool I could pick up at a hardware/autoparts store?
Old Mar 4, 2004 | 06:35 AM
Ryan3933's Avatar
Default Re: (bwdc2)
Take that $120 dollars and buy some tools and do the job yourself. Then next time you'll know how to do it and you won't have to worry about being ripped off.
If you decide to DIY, don't forget to buy a high quality torque wrench. Also, did you get new springs to go with the Konis?
Old Mar 4, 2004 | 06:41 AM
DA Teg D00D's Avatar
Default Re: (Ryan3933)
do it yourself...you'll never learn anything about your car by letting other ppl do it for you.
Old Mar 4, 2004 | 06:59 AM
MAV3RiCK478's Avatar
Default Re: Labor cost on strut/shock replacement (bwdc2)
i agree, do it yourself. there's no other feeling like working on your car and finishing the job.
POOP, i miss g2ic.
Old Mar 4, 2004 | 07:19 AM
631 Teggy's Avatar
Default Re: Labor cost on strut/shock replacement (MAV3RiCK478)
All you gatta do is take the shock and spring off (bolts to LCA, and to the body), compress the spring and unskrew the bolt on the hat of the shock, then just take off the spring...
It took me about 15 minutes to do when I adjusted mine...
You'll need something to compress the spring in most cases, sometimes you can have a buddy tie something to the spring and pull it down wile you screw on the hat... You can buy a shitty hand-held spring compressor for falry cheap... The larger units are a lot of money - but they aren't necissary for little honda springs...
Don't pay $150
Old Mar 4, 2004 | 07:21 AM
SweetChin's Avatar
Default Re: Labor cost on strut/shock replacement (balch104)
if you have lowering springs your not gonna need a spring compressor, but if your still on stock springs you can get spring compressors cheap at any auto parts store... some places will even let you rent them out
Old Mar 4, 2004 | 08:00 AM
timmy8151's Avatar
Default Re: Labor cost on strut/shock replacement (SweetChin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SweetChin &raquo;</TD></TR><TR><TD CLASS="quote">if you have lowering springs your not gonna need a spring compressor, but if your still on stock springs you can get spring compressors cheap at any auto parts store... some places will even let you rent them out</TD></TR></TABLE>
You don't necessarily need a spring compressor, but it's recommended. I got my compressor at Autozone, where I had to put down a $50 deposit. If you want to buy your own set Harbor Freight sells their spring compressor for $11.
Old Mar 4, 2004 | 08:22 AM
Devlins 91LS's Avatar
Default Re: Labor cost on strut/shock replacement (timmy8151)
easy spring decompression:
Remove spring/strut assembly from car
Place old shop towel on floor
Place strut lengthwise on the towel, ie, paralell with the skinniest sides.
Fold the back 1/3 over the strut, then the front 1/3.
Cut a hole in the towel for the strut assembly nut to stick out
Point strut away from anything valuable (ie. point it at a wall)
Stand on the two "wings" that you got from folding the towel over
Place allen wrench in tip of strut, and use open ended wrench to remove the nut.
It'll eventually pop off, but it doesn't have all THAT much force. I stuck a cardboard box in front of mine when i did it and it didn't knock the box over.
NOTE: I don't reccommend doin this on say, a suburban or truck or anythin, but it works jsut fine on a stock integra/civic/crx/delsol/etc i've done this exact process like 8 tiems and it works just fine.
Old Mar 4, 2004 | 10:03 AM
631 Teggy's Avatar
Default Re: Labor cost on strut/shock replacement (Devlins 91LS)
getting it off it the easy part... Without a spring compressor it will be a bitch to get back on...
Old Mar 4, 2004 | 10:12 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAV3RiCK478 &raquo;</TD></TR><TR><TD CLASS="quote">i agree, do it yourself. there's no other feeling like working on your car and finishing the job.
POOP, i miss g2ic. </TD></TR></TABLE>
what happen to g2ic?
Old Mar 4, 2004 | 10:20 AM
Default Re: Labor cost on strut/shock replacement (projectTeG)
changing servers, its been a week since its been down. i think im gonna pass out soon, lol.
Old Mar 4, 2004 | 03:03 PM
r34p3r666's Avatar
Serious, d00d ... I need my meet info !!!
sh!ft
Suspension & Brakes
Mar 23, 2011 04:02 PM
dylanear
Suspension & Brakes
Jun 23, 2008 07:39 AM
lonebun
Mar 23, 2007 04:03 PM
TauMax
Feb 2, 2005 07:55 PM
mps9506
Sep 22, 2001 10:39 PM
