Many Miles To break in Engine LSVTEC?
Well just about finished my LS Vtec. Bout a b1.6 Superchaged but sold it.
I put a b1.6 Head with a Ls block and b1.6 Internal. I also has a Skunk 2Intakemanifold. So how many miles do you think. One person told me 3000 miles someone else said 500 miles?
Start the car up and let it idle for 30 min. Take the car out and do some 30-50mph 3rd & 4th gear pulls and decel w/o brakes or downshifting. Rings are seated. Be easy for 500 miles. Drive normal for 1000 (not hard or soft) Then go have fun.
If your not building the block then there is no need for a lot of mileage break-in. I would say 200 milages. but if ur building the block there is a 500 mileage breaKIN for sure. Mine was 500 miles, you gotta slow your roll for a while
drive 200 miles then change your oil, then drive another 400 miles and change your oil again. and lastly, drive another 400 and change your oil again. this is how i broke in my motor
. doing all that oil changing removes all the metal shavings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilredridinghood »</TD></TR><TR><TD CLASS="quote">drive 200 miles then change your oil, then drive another 400 miles and change your oil again. and lastly, drive another 400 and change your oil again. this is how i broke in my motor
. doing all that oil changing removes all the metal shavings </TD></TR></TABLE>
Is this true? It sound right but I never heard this before?
. doing all that oil changing removes all the metal shavings </TD></TR></TABLE>Is this true? It sound right but I never heard this before?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DreK9 »</TD></TR><TR><TD CLASS="quote">
Is this true? It sound right but I never heard this before?</TD></TR></TABLE>
Yeah it makes a lot of sense and it adds up to 1000 miles.. Theres no reason not to do it.. How much is an oil change if you do it yourself.. $10?
I just wnated to know if you had any problems with you lsvtec. Reason why I am asking is that I am getting aprts right now for it. What parts do i need to do a lsvtec that wil lrun well with minmal problems. I wnat to do it right now so I wont haveany problems later? If you have some time just tell me which parts I would need for a complete lsvtec
Refer to Hastings MFG website
http://www.hastingsmfg.com/service_tips.htm
Go to break in procedures.
I had a thread abotu this already too.
https://honda-tech.com/zerothread?id=862940
-sander
-sander
BITCHES! everyone ****** one of you are bitches! and ignorant!
**** 500 miles. drive that ************ hard as hell after you let it come up to running temperature to check for any leaks. actually, on your very first run, you put a slight load on the engine, either starting out in 2nd or driving 1st up a good hill. run it up thru all the gears, going to about 3/4 throttle. run it back down the gears, DOWNSHIFTING! after that, drive it just how you would after it has been broken in. you got to get rod stretch, cylinder wear, and your rings seated. you will feel the rings seat, the power coming up slowly but surely. just dont run it at steady rpms for longer than 1 mile during the first oil change. oil should be changed after 500 miles.
Re: Many Miles To break in Engine LSVTEC? (alloysr16s) » 5:41 PM 6/30/2004 Reply Edit
Well what car do u have? And what set up are you goin for? Turbo? All Motor?
Well I am going for all motor. I am also going to may, Now I mean may have nitrous. But that is a very long strecth. I am a daily driver so I need to know what is all the possible parts I would need
Lei Siew Long
Mar 4, 2002 02:47 AM
