throttle positioning sensor replacement
Old Mar 3, 2004 | 11:02 AM
gabspeed's Avatar
Default throttle positioning sensor replacement
does anybody knows if it is acually posible to replace a TPS without having to replace the whole Throttle body? if so, how?? thanks in advance
Old Mar 3, 2004 | 11:20 AM
cbstd's Avatar
Default Re: throttle positioning sensor replacement (gabspeed)
On my Old School CRX, the TPS is secured with headless screws. I cut a slot into the top of the screws with a Dremel (my favorite tool) and simply unscrewed the screws holding the TPS in.
The problem is that you can not just buy a TPS from Honda. Maybe your local junkyard is more sympathetic.
Scott
Old Mar 4, 2004 | 06:02 AM
gabspeed's Avatar
what would be the symtomes of a bad TPS? could it be making the car run rich or lean? or retirding the timming? thanks
Old Mar 4, 2004 | 06:11 AM
Daemione's Avatar
Yup, cbstd is correct. Run a search for plenty of info.
chrisff521
Apr 5, 2009 07:26 PM
cazper8890
Mar 2, 2007 08:25 PM
nutball72
Nov 11, 2006 07:14 PM
GSRcivicGSR
Dec 20, 2004 04:29 AM
Redsim
Jun 11, 2003 09:37 PM
