too much oil bad?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99b18 »</TD></TR><TR><TD CLASS="quote">yes this can cause too much crankcase pressure. which will blow your oil pan seal.</TD></TR></TABLE>
Actually, the real reason why too much oil is bad is that if it is up to the level of the crank, it tends to get whipped by the crank. This causes foaming. And foamy oil does not lubricate well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">
Actually, the real reason why too much oil is bad is that if it is up to the level of the crank, it tends to get whipped by the crank. This causes foaming. And foamy oil does not lubricate well.</TD></TR></TABLE>
good call
good call
actually they are both real reasons. thank u for pointing out the second one. no need to be rude though.
