how do you start up after an oil change?
Old Mar 3, 2004 | 02:57 AM
an2ny888's Avatar
Default how do you start up after an oil change?
from past experience the red engine oil light stays on a looong time when you start up just after an oil change, like maybe 2 seconds. was thinking of putting in a little oil in the filter before installing it, or maybe pulling the ecu fuse and starting the engine for a few seconds to prime up the oil pressure. any comments?
Old Mar 3, 2004 | 03:01 AM
d8168055's Avatar
Default Re: how do you start up after an oil change? (an2ny888)
its totally normal... the new oil hasnt entered the engine yet, so it will think it is low... once it is kicked up by the crank, then the light will turn off...
Old Mar 3, 2004 | 03:21 AM
.RJ's Avatar
.RJ
Default Re: how do you start up after an oil change? (d8168055)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d8168055 &raquo;</TD></TR><TR><TD CLASS="quote">the new oil hasnt entered the engine yet, so it will think it is low... once it is kicked up by the crank, then the light will turn off...</TD></TR></TABLE>
That light is a pressure warning, not a volume indicator.
Old Mar 3, 2004 | 03:44 AM
DAsix's Avatar
I wont let my car get that low.
Old Mar 3, 2004 | 04:23 AM
Jon D's Avatar
Default Re: how do you start up after an oil change? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
That light is a pressure warning, not a volume indicator.</TD></TR></TABLE>
^^^^What he said^^^^
Old Mar 3, 2004 | 04:25 AM
DeL SLo's Avatar
I roll my itr off a cliff.
Old Mar 3, 2004 | 04:38 AM
BudMan's Avatar
Put at least 1/2 filter full of oil. When you are putting it in the filter, wait a sec, because it will take a few seconds to flow through the filter & then you can add some more. I've never had the oil light come on during startup after an oil change.
Old Mar 3, 2004 | 04:39 AM
Dave-ROR's Avatar
Default Re: (DAsix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAsix &raquo;</TD></TR><TR><TD CLASS="quote">I wont let my car get that low.</TD></TR></TABLE>
what the hell does this have to do with the thread?
Old Mar 3, 2004 | 07:11 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Dave-ROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave-ROR &raquo;</TD></TR><TR><TD CLASS="quote">what the hell does this have to do with the thread?</TD></TR></TABLE>
I don't know, but it certainly has more to do with the thread than this other post:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeL SLo &raquo;</TD></TR><TR><TD CLASS="quote">I roll my itr off a cliff.</TD></TR></TABLE>
Old Mar 3, 2004 | 07:19 AM
mstewar's Avatar
idiot light..
Old Mar 3, 2004 | 07:25 AM
markpaco's Avatar
Default Re: how do you start up after an oil change? (BudMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BudMan &raquo;</TD></TR><TR><TD CLASS="quote">Put at least 1/2 filter full of oil. When you are putting it in the filter, wait a sec, because it will take a few seconds to flow through the filter & then you can add some more. I've never had the oil light come on during startup after an oil change.</TD></TR></TABLE>
Same here. I always prime my filters when I change my oil. That way there is less time that the motor is running w/o oil. Have you ever heard a Toyota or Chevy motor start when it gets its oil changed? It is pretty noisy. That is why I always prime my filters.
Old Mar 3, 2004 | 07:47 AM
.RJ's Avatar
.RJ
Default Re: how do you start up after an oil change? (mstewar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">idiot light..</TD></TR></TABLE>
It might as well be green and shaped like a "$"
By the time it goes off, thats all you'll be seeing.
Old Mar 3, 2004 | 08:02 AM
Footwork's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BudMan &raquo;</TD></TR><TR><TD CLASS="quote">I've never had the oil light come on during startup after an oil change.</TD></TR></TABLE>
Old Mar 3, 2004 | 08:38 AM
95dc2's Avatar
tru
stockgreencivic
25
Dec 16, 2005 06:15 AM
vietnogi
Jul 17, 2005 02:23 PM
lemongreenhatch
10
Aug 15, 2004 06:47 AM
an2ny888
Apr 3, 2004 03:10 PM
rota426
Jun 3, 2003 09:55 AM
