Attempted to tune my car today, but it didn't go so well...
I went to go tune my turbo charged civic si today, and supposedly my 3 bar map sensor is not reading boost. It's still seeing vacumm when boosting so we're going to see what happens when I put the stock map sensor back on tomorrow. We did a few base line runs. I believe the numbers were 196 whp at 8 psi, but we didn't go any further after the map sensor issue...
EMS (Hondata S100B installed on a P30 JDM OBD I ecu / with RC 550 injectors)
Anybody know what could be going on???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostn420 »</TD></TR><TR><TD CLASS="quote">You dont have a checkvalve in there right?</TD></TR></TABLE>
No check valves...
No check valves...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostn420 »</TD></TR><TR><TD CLASS="quote">Sounds like a broken sensor or it uses a different voltage range than required.</TD></TR></TABLE>
We checked the voltage and it was reading fine... Plus if it was a faulty map sensor it should through a check engine light, but it's not throwing any trouble codes.
