HELP:92-dx head taller than the a6 head?
Old Mar 1, 2004 | 11:57 AM
turbo_ef9's Avatar
Default HELP:92-dx head taller than the a6 head?
my friend bent his valves in his 90 ex with an a6.. he wanted it running asap so i swapped it over for a 93 dx head.. the car doesnt start anymore.. it's getting spark and fuel.. but... the weird thing is that when i pull the plugs after i tried to crank it, its fouled with fuel... i know it sparks cuz i did a test on it... it seems as if the spark plug wire isn't reaching the spark plugs, making it so it doesn't spark.. so.. is the dx head taller than the a6 head? i tested a few plug wires and the old ones dont reach down far enough for the plugs.. what do you guys think?
Old Mar 1, 2004 | 12:20 PM
turbo_ef9's Avatar
Default Re: HELP:92-dx head taller than the a6 head? (eli_vang)
anyone?
Old Mar 1, 2004 | 12:28 PM
Redline130's Avatar
I thought that the heads were basically the same physically. Hmmm, is the timing OK?
Old Mar 1, 2004 | 12:33 PM
4drEF's Avatar
Keyboard Humorist
Compression check.
Make sure you put the plug wires to the right place.
Check belt timing.
Check all wire connections and grounds.
Old Mar 1, 2004 | 01:19 PM
turbo_ef9's Avatar
Default Re: HELP:92-dx head taller than the a6 head? (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">Compression check.
Check belt timing.
Check all wire connections and grounds.</TD></TR></TABLE>
plug wires are in the right place.. timing belt is fine.. grounds are fine.. timing is correct.. this isn't the first head i've done.. its like the 15th.. like i said.. the old plugs dont go down all the way to connect to the top the the plugs.. anyways... i made the dude buy some new plugs and wires so i'll go check it out later today..
Old Mar 1, 2004 | 01:41 PM
91civicDXdude's Avatar
the head casting is physically identical
Old Mar 1, 2004 | 02:30 PM
turbo_ef9's Avatar
Default Re: (91civicDXdude)
i was thinking that.. the why the f*ck dont the plug wires reach down far enough to the plugs..
Fatdicklegend
Feb 15, 2015 04:40 PM
EJAYATE
Honda S2000
Sep 22, 2010 10:09 AM
092eg6
Jun 30, 2009 11:28 AM
junior40er
23
Jun 14, 2006 04:49 PM
turbo_ef9
Mar 1, 2004 12:19 PM
