Best Plug for 550+
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid901 »</TD></TR><TR><TD CLASS="quote">What is the best NGK plug for over 550whp? I was running a 9 heat range plug last year but forgot the part number.</TD></TR></TABLE>
See my thread and the second post under this thread. That should help.
https://honda-tech.com/zero...age=1
This also may help?
This also may help?
for low hp the bcpr7es11 is most common plug
the 5671-a plugs are usually good for racing only not really used on street that often. mostly a race type plug. i used to run the 9s 10s and 11s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">Will any auto part store have them? Can I just take that part number [bcpr7es11] and get them?</TD></TR></TABLE>
part number from NGK is 1095 ask for that at napa or any local parts store
i'm assuming i would need the 8's then.. i'm curently running bcpr7es's and i am misfireing/stumbling badly up top at 75%-100% throttle, this was only at about 10 psi on my stock gsr.. they were gapped at .030 as well.. when i regapped them to about .020, my full throttle was smooth, but idle sucked real bad..
bump..
bump..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 »</TD></TR><TR><TD CLASS="quote">you should not be having a problem w/ the 7's @ .030 on a stock GSR. There is something else wrong w/ ur set up then.
On the real, i was running the 7's and made 450whp.
ngk R5671a-8 part# is 4554
ngk R5671a-9 part# is 5238
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid901 »</TD></TR><TR><TD CLASS="quote">ngk R5671a-8 part# is 4554
Those happen to be the 2 different plugs I ordered earlier, 8 of each.</TD></TR></TABLE>
Keep us posted cause I am curious. My thought was 9's but 8's might be OK.
Good luck.
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">Higher or lower number with more horsepower?</TD></TR></TABLE>
Higher. The higher the number the colder the plug.
TeamTooQuick
Aug 9, 2003 07:23 PM
