Has anyone installe the ENDYN block breather kit while the engine is still in the car?
i assume if its possible the intake mani has to come off but i still dont know if thats enough room to get the freeze plugs out
I did mine with the engine in the car. . . .well i already had the freeze plug in and the ports. But then i mounted the can and routed the lines with it in the car
I installed one on a friends car. I took the intake manifold off then used a 14mm hex socket with a huge breaker bar and popped off the freeze plugs. Just make sure you give yourself room to work when loosening the freeze plugs. later
ryan,
how's the car running?
edit: i would also add extra breather ports off the valve cover in front like tbone and endyn have done. You could just do a seperate breather for that. Summit sells a breather/catchcan for like $35. I think that's the way to go.
s
s
the car is running sweet the owner was super happy and we already have Greddy catch cans in stock at CCR but we still need to order the ENDYN kit.
anyone have a picture of Tbone's setup off the valve cover? I would like to see if everyone is using a seaparate tank or having it welded with 3 fittings instead of 2?
Propulsion
Nov 24, 2003 03:55 PM
