Thermostat Problem - ONE QUICK QUESTION
Old Mar 1, 2004 | 02:18 AM
Louie_EM1
Guest
Posts: n/a
Default Thermostat Problem - ONE QUICK QUESTION
Yeah I searched; a lot of help yet one question still remains a mystery.
My fan wasn't turning on so I decided to jump the ECT switch (thermoswitch) and yay it worked; first time I've seen that fan go on for maybe a year; never had an overheating issue.
Anyways, I bled the coolant a few days back and I think I may still have air in it even though I did run with the car on for like 15mins with the radiator cap off.
I will be replacing the thermostat as well due to I don't want that being broken as well, I donno if I have a bad thermostat but I will be assuming I do, mind as well change it while it's there.
Will a bad thermostat or a bad thermoswitch be a cause for bad bleeding?
Also when I bleed the coolant I never saw 'bubbling' coolant come out...it accutally spilled out slightly; is it supposed to bubble, what am I looking for as for as actions from the radiator cap?
Thanks a lot.
Old Mar 1, 2004 | 04:15 AM
wilsel's Avatar
Default Re: Thermostat Problem - ONE QUICK QUESTION (Louie_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Louie_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">Will a bad thermostat or a bad thermoswitch be a cause for bad bleeding?
Shouldn't, even with the thermostat "closed" coolant still circulates.
As far as bleeding, you'll see coolant stream out, then air bubbles, coolant streaming, bubbles. If for 10 secs you don't see any bubbles you probably have all the air out of the system. You said you hadn't seen the fan come on for a long time. I would guess it's the thermoswitch then. Wouldn't hurt to do the thermostat at the same time for a few extra $.
Old Mar 1, 2004 | 04:26 AM
wilsel's Avatar
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">Isn't there a little valve on the thermostat housing to bleed the coolant system? Gotta open it until no more bubbles appear then close it and you're done?</TD></TR></TABLE>
It's on the upper radiator hose housing.
Old Mar 1, 2004 | 05:29 AM
Louie_EM1
Guest
Posts: n/a
Default Re: Thermostat Problem - ONE QUICK QUESTION (wilsel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wilsel &raquo;</TD></TR><TR><TD CLASS="quote">
Great information, thanks it really cleared what I was looking for.
Old Mar 1, 2004 | 05:30 AM
Louie_EM1
Guest
Posts: n/a
Default Re: (Dimi)
I believe this is on earlier models. B16a2 does not have em.
Spec R
Jun 17, 2006 05:04 AM
M2B4
Apr 20, 2006 09:56 AM
stealth civic
Jan 13, 2005 09:03 AM
W.Zero
12
Dec 27, 2003 06:10 PM
