Could my Synchro be on it's way out ?
Old Feb 29, 2004 | 01:13 AM
Illusion-Paul's Avatar
Default Could my Synchro be on it's way out ?
i am have this problem,
I changed the clutch on my ITR about a month ago, i just changed the clutch plate as the other one had been damaged, (it was a get me by till i get a lightened clutch)
now when i am driving hard,sometimes, when i change up or down to 3rd gear it crunches when putting it in. It doesn't do it when driving normally or when i start to drive hard, only when i am driving quite hard.
I have checked the oil, its full, someone said i should bleed the clutch ?
Does it sound like the synchro is on its way out ???
Thanks
Old Feb 29, 2004 | 01:37 AM
yellow blur's Avatar
Default Re: Could my Synchro be on it's way out ? (Illusion-Paul)
Classic Honda 3rd gear sycnro problem. Mine does the same thing when im hauling *** and I put it into 3rd quickly.
I think what some might suggest is to try and use GM Syncromesh or some sort of fluid like that. It's only a temporary band-aid solution though.
Ed
Old Feb 29, 2004 | 01:50 AM
thanks for that, ]
it just seems since i changed the clutch it had got worse, what do you think would be the best option, replacement box, different ratios or just replace the synchros ?
Old Feb 29, 2004 | 09:15 AM
Dr Pooface's Avatar
Default Re: (Illusion-Paul)
Try changing the tranny fluid. That always seems to help me.
Old Feb 29, 2004 | 09:18 AM
B2FiNiTY's Avatar
Best options are to change the fluid and see if that does anything. If not, then all you need to change is the syncro.
Old Feb 29, 2004 | 04:51 PM
danny98r's Avatar
when i put in a performance in my car i noticed that my 3rd gear was grinding too at high rpms. its def ur synchro man. i had acura warranty it under a good will service. my stock clutch was put back and now it is like new again. i tried gm synchromesh and did not do the trick. trust me this crunch gets annoying i would pay anything not to have that crunch again. bloody 3rd gear synchros suk bro. get it fixed
danny98r's Avatar
performance clutch "typo"
Old Feb 29, 2004 | 04:57 PM
98itR484's Avatar
Default Re: Could my Synchro be on it's way out ? (danny98r)
I got the same problem. I change out the GM Syncromest every 3k miles or so, after every change the grind goes away, then 3k miles later its back. Im just toooo lazy to pull that tranny off again jut for the 3rd gear syncro. I'll just wait until i need another clutch, or until i get the ATS gears
Old Feb 29, 2004 | 10:20 PM
Syner-G-Racing LLC's Avatar
Default Re: Could my Synchro be on it's way out ? (98itR484)
run a cushioner like they say you can also just use an additive, till you can replace the syncro, it will only get worse trust me. replace it...............replace it..............replace it............youll thank yourself for it later when you see you freind replacing pilot bearings and bending their shifter forks trying to hit second.
Old Mar 1, 2004 | 08:29 AM
goodbyegti's Avatar
it isnt always the syncrho, rear engine mount can cause grinding...
Old Mar 1, 2004 | 09:03 AM
mikestypeR
Guest
Posts: n/a
OWNED BY THE THIRD GEAR SYNCRO MADNESS!@
why hasnt someone produced an aftermarket heavy duty syncro that will last?????????????????????????????????????????????? ??????
Old Mar 1, 2004 | 12:14 PM
JDM CTR EK's Avatar
Default Re: Could my Synchro be on it's way out ? (mikestypeR)
OHHHH NOOOOOO!!!!! Honda's 3rd gear!!!! it's ok i am having the same problem. too lazy to change it out.. I just drive shift at 3-4k instead at da 9k
Old Mar 1, 2004 | 12:18 PM
RTW DC2R's Avatar
give the GM synchromesh a try, worked very well for my 3rd and 1st gear grinds and shifts very smooth. No problems since and should help avoid further damage until you can get it repaired the right way.
02_Si_FTW
Jul 21, 2008 01:57 AM
Jeff_B
Dec 10, 2004 09:21 AM
H.
Oct 10, 2004 07:05 PM
4DRmafia
Jul 8, 2004 08:36 PM
pinoyboy204
Apr 28, 2004 03:59 PM
