Clutch Problem
Old Dec 9, 2004 | 10:39 PM
Jeff_B's Avatar
Default Clutch Problem
Was driving home today and randomly it became very hard to put it into any gear... this continued all the way till I got it home. Also, starting in first from a stop, the car would stumble till it reached higher RPMs. However, it is still able to start in 2nd gear (with the same stumbling obviously). Mileage is 81,000... what do you guys think?
Old Dec 9, 2004 | 10:49 PM
CNSK's Avatar
Default Re: Clutch Problem (ChassisInnovations)
it could be your clutch......my clutch went out on me also bout 2 weeks ago....I could start it but could not put it into any gear. Started out as having a hard time putting it in gear to not being able to put into gear at all. Just opened up my transmission yesterday and yup my springs busted everywhere when I took off my clutch. It was a stock clutch since 95 and I have bout 180k miles...so its time for a new one.... Try bleeding your clutch line and see if it will help it out
Old Dec 10, 2004 | 09:21 AM
Jeff_B's Avatar
Default Re: Clutch Problem (Moua)
Well, I already checked the CSC and CMC for leaks, and they were none apparent. There were also no leaks around the clutch pedal. Also, there is fluid present and it was bled about a month and a half ago.
Hemix
11
Jun 30, 2008 11:25 AM
old_school_dohcvtec
Oct 4, 2007 09:47 AM
kydragger
Feb 17, 2003 10:55 AM
hybrider
Aug 3, 2002 06:20 PM
