max bore wanted on a sleeved turboed b16a
Old Feb 28, 2004 | 01:50 PM
regime's Avatar
Default max bore wanted on a sleeved turboed b16a
alright ive searched... figued i should since i tell ppl to all the time
i plan on getting my b16a block sleaved for when i turbo it, and wanted to know what size bore would be best for it.
should i just go max and crank up the displacement, keep it stock bore, or put it somewhere in the middle.
my logic says go like 85, but then again i dont have nething to base this on so i dont know, and would the cooling jackets get to small going this big? thanks
-Jeff-
Old Feb 28, 2004 | 06:46 PM
regime's Avatar
Default Re: max bore wanted on a sleeved turboed b16a (regime)
i know there are some turboed b16's out there whos owners know about this stuff
Old Feb 28, 2004 | 07:30 PM
94gsr4dr's Avatar
84mm seems to be a popular choice. Lots of people will tell you to use caution going 85-86, but its your car. Piston selection becomes more difficult with those larger bores as well.
Old Feb 28, 2004 | 10:11 PM
Civic Power's Avatar
New User
I run 84mm with 9.5:1 Comp .
Old Feb 28, 2004 | 10:29 PM
Boostfed's Avatar
New User
Default Re: max bore wanted on a sleeved turboed b16a (Civic Power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic Power &raquo;</TD></TR><TR><TD CLASS="quote">I run 84mm with 9.5:1 Comp .</TD></TR></TABLE>
Me too now! I have had 84.5 then 85mm. Of course when I have to rebuild I will overbore to 84.5mm and new pistons or coat the existing pistons.
Old Feb 28, 2004 | 10:32 PM
earl's Avatar
Benson has an 86mm b16 sleeve available. It is done by using Prelude sleeves and lots of precision machine work.
Old Feb 28, 2004 | 10:58 PM
m R g S r's Avatar
Default Re: max bore wanted on a sleeved turboed b16a (earl)
I'm starting an 85mm b16, it should be done in a month or so!
Old Feb 28, 2004 | 11:43 PM
IntegracinGSR's Avatar
Earl, can they do the same with b18c1 blocks and the prelude sleeves? What pistons would be available for that setup?
Old Feb 29, 2004 | 12:42 AM
B18C1_T's Avatar
Default Re: (IntegracinGSR)
um how about ARI sleeves cause there a block for sale, and now im wonder how far of big bore can they go!
Old Mar 1, 2004 | 06:05 PM
B18C1_T's Avatar
up some could you plz ansewer my Question
Old Mar 1, 2004 | 07:39 PM
regime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Benson has an 86mm b16 sleeve available. It is done by using Prelude sleeves and lots of precision machine work. </TD></TR></TABLE>
thanks for the info all
and as soon as i start to get some cash together and start my build you can expect my business earl =D
so what im gathering is the bigger the bore the better?
what about the cooling jackets getting too small? or is it a non-concern with something like 85 or 86?
edit: ive looked into running arias low compression pistons and they stock the biggest size of 84.5
i know i can go custom, but that would be really pricey im assuming (as if building an engine isnt)
so do you all know who may stock a 85 bore or even an 86? ive looked but cant find ne from wisco, je, cp, etc. thanks
Modified by regime at 12:11 AM 3/2/2004
Powered by VTEC
10
Dec 18, 2007 08:51 AM
5_Lug_B
Aug 14, 2007 12:03 PM
psegs80
Jul 31, 2006 05:53 AM
dpine
Feb 28, 2004 11:05 PM
Importracer_001
Sep 2, 2003 03:19 PM
