max bore size on b16a?
Old Feb 25, 2004 | 05:04 PM
dpine's Avatar
Default max bore size on b16a?
Does anyone know the maxium size I can bore a b16a to? I was planning on boring to 82mm, and I just wanted to know if that would be safe for a street motor. I just wanted some opinions on this, good and bad. Anyone running this set up? I have searched.
thanks
Old Feb 25, 2004 | 05:28 PM
KMaxwell's Avatar
Default Re: max bore size on b16a? (dpine)
if i were you i would call golden eagle, i have talked to them many times about bores and strokes for blocks. they will custom make you any piston size you want
Old Feb 25, 2004 | 05:33 PM
maxt's Avatar
also want to know.
Old Feb 25, 2004 | 05:54 PM
dpine's Avatar
Default Re: max bore size on b16a? (KMaxwell)
the reason why I ask is because I am thinking about the b16 stroker kit from eagle. Its seams to have a good r/s ratio from what I have looked at. I think it comes with 82 mm pistons and I am some what on a budget. I happened to get a bare b16a block for free.
Old Feb 26, 2004 | 07:48 PM
Cornwhiskey's Avatar
is this going to be a all motor...motor
Old Feb 26, 2004 | 09:14 PM
ExospeedAMcrx's Avatar
Default Re: max bore size on b16a? (onefastcrx88)
the max bore size recommended on a non-sleeved block is 82mm.
if you sleeve it, you can bore to 87mm(full racesetup) and 84mm for street is fine.
i highly suggest doing the sleeving over the stroker since its simpler. the eagle stroker kits are good, but for similar amount of money, you have a SLEEVED block already.
I know people are going to argue about R/S ratio and all, but honestly, how important is it really. we turn street lsvtec motors up to 9500rpm and pushing 220 hp to the wheels. no problems and still reliable. r/S ratio is a good thing to follow in theory. but not necesarry to make good power and to make a great motor.
Old Feb 27, 2004 | 05:24 AM
dpine's Avatar
Default Re: max bore size on b16a? (exospeedAMcrx)
the only reason for the stroker kit is because the block that I have is bare, ,no pistons, crank, rods. I would have to buy all that and the sleeves (I'm a cheep ***). But i will ask what is the going rate for a sleeved block from exospeed?
Old Feb 27, 2004 | 08:16 AM
sleving service is $880 and includes the bore to size you want, hone, hot tank, deck,
Old Feb 27, 2004 | 01:03 PM
dpine's Avatar
thanks. I will have to think about it.
Old Feb 27, 2004 | 01:04 PM
dpine's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefastcrx88 &raquo;</TD></TR><TR><TD CLASS="quote">is this going to be a all motor...motor</TD></TR></TABLE>
Yes.
Old Feb 28, 2004 | 05:14 AM
check ur pm
Old Feb 28, 2004 | 08:11 AM
mmuller's Avatar
Mad Scientist
as sayd avobe, 82mm
Old Feb 28, 2004 | 09:46 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpine &raquo;</TD></TR><TR><TD CLASS="quote"> the only reason for the stroker kit is because the block that I have is bare, ,no pistons, crank, rods. I would have to buy all that and the sleeves (I'm a cheep ***)</TD></TR></TABLE> Hey, no problem being a cheap ***, many of us here are just that... and everyone looking over the classified section here definitely IS.
Okay you ready for option #3?
-Buy an LS crank and rods... cheap.
-Order custom pistons that have the pin hole made smaller and also moved so that you can use the LS crank AND the LS rods in your B16 block that is shorter-than-a-B18-block. I lost the thread but there are guys offering these pistons for about $650 a set. You may also need a bushing installed on the rod ends for the smaller pin.
-This setup gives you LS displacement and retains your B16 block. done. "poor mans stroker" I guess if you compare it to full setup from Crower, Eagle, etc.
-This would also work with GSR or ITR crank and rods instead of LS crank and rods, but be sure to be clear to your piston mfg'er on what you are running!
cool huh? not like you have more $$ but iff you did, you could combine the poor mans stroker with a sleeved block and run 84mm pistons for a 1.9+ liter motor in a B16 stamped block... NICE!
Old Feb 28, 2004 | 11:05 PM
gambo117's Avatar
go with 84 sleeved block. the bore gives you more displacement than the stroke, dont make me break out geometry. as someone else said you can use a stock ls crank, and custom rods and pistons and have thebest of both worlds. i think honda tuning did it, although they used the probe kit.
RACEPAK
Apr 6, 2010 02:24 AM
Christopherian1982
Jan 20, 2009 09:52 PM
5_Lug_B
Aug 14, 2007 12:03 PM
TheYellowDart
Mar 26, 2004 09:36 AM
hybrid88hatch
Jun 5, 2003 07:33 PM
