rear LCA bolt broken off... Please HELP Me..!!!!!
Old Feb 28, 2004 | 12:28 PM
. o 69 o .'s Avatar
Default rear LCA bolt broken off... Please HELP Me..!!!!!
https://honda-tech.com/zero...82682
Old Feb 28, 2004 | 12:35 PM
=GAME='s Avatar
Default Re: rear LCA bolt broken off... Please HELP Me..!!!!! (B16B)
when mine was stripped, i use a die grinder and grinded the head of the bolt off. then i went went ahead a drilled a little hole enough to stick the craftsmans screw out and it just came right out. itll take some time to do.
Old Feb 28, 2004 | 02:04 PM
. o 69 o .'s Avatar
Default Re: rear LCA bolt broken off... Please HELP Me..!!!!! (=GAMEOVA=)
the problem is that this is seized. I had been soaking it with penetrating oil every day for a week in hopes that it would be freed up by the time i wanted to take them off.
I cannot drill through it because the material is too hard. If i had a torch, id cut that sheit out
Old Feb 28, 2004 | 02:29 PM
. o 69 o .'s Avatar
Default Re: (OOsi)
i dont care about the lca's because i have JDM ones to replace them. I am worried about the subframe. It is also not as easy to "just turn the pointy screw" because it is seized. This is what caused the problem in the first place.
kyorishin
Apr 11, 2006 11:02 PM
HatchBox
22
Jun 30, 2004 04:02 PM
MeanGreenEG9
Sep 18, 2002 04:24 PM
Peter K
Apr 19, 2002 05:53 AM
Peter K
Apr 6, 2002 01:44 PM
