replacing inside door handles.....how hard?
Old Feb 27, 2004 | 03:23 PM
92hondaex's Avatar
Default replacing inside door handles.....how hard?
I need to replace both inside doors handles on my '92 accord. I was wondering how hard it is to do. Has anyone done this before. Any tips I should know that will help me out?
I heard this is a common problem with these cars.
Old Feb 27, 2004 | 03:38 PM
Spider Man's Avatar
Default Re: replacing inside door handles.....how hard? (92hondaex)
It should be cake, I take out my door panel all the time.
Which part are you replacing?
Old Feb 27, 2004 | 04:01 PM
92hondaex's Avatar
Default Re: replacing inside door handles.....how hard? (Spider Man)
I am replacing both inside door handles.
Old Feb 27, 2004 | 04:40 PM
jwogen1's Avatar
chiltons manual will be your friend....
Old Feb 27, 2004 | 05:36 PM
Spider Man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondaex &raquo;</TD></TR><TR><TD CLASS="quote">I am replacing both inside door handles. </TD></TR></TABLE>
I have not noticed that it is a common problem with this gen.
I do however have a clue as to HOW this problem occurs.
WAY too many of my passangers LOVE to get out of the car before the engine is off. Since my alarm auto locks the doors, when they try to open it won't and they think they need to pull harder and so they pull as hard as they can till I notice it and yell at them to stop.
As for replacement, it will be easy.
The most common problem with that gen accord is the dam antenna mast, they ALL break.
Old Feb 27, 2004 | 08:06 PM
fliplyricist1's Avatar
yeah, ahmen to that.
fortunately/unfortunately my aftermarket radio doesn't even trigger the raising/lowering of the antenna even though the wire is connected
oh well...who listens to radio anyways nowadays
Old Feb 27, 2004 | 10:02 PM
Spider Man's Avatar
Default Re: replacing inside door handles.....how hard? (fliplyricist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fliplyricist &raquo;</TD></TR><TR><TD CLASS="quote">yeah, ahmen to that.
oh well...who listens to radio anyways nowadays</TD></TR></TABLE>
Funny thing is.
I don't, but I fixed the antenna anyways after 5 years and I still don't use it!
LOL
Old Feb 28, 2004 | 06:56 AM
fluxion's Avatar
amin n'rangwa edanea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spider Man &raquo;</TD></TR><TR><TD CLASS="quote">
The most common problem with that gen accord is the dam antenna mast, they ALL break.</TD></TR></TABLE>
exactly, everytime i stop the car, no matter how many times i bitch, the passenger will start yanking on the ******* handle like the car is about to explode.
i've replaced two handles on my 5th gen, i'm not sure how much different it is for a 4th gen, but in my case removing the door panel wasnt even necessary. you just pop a little cover off the handle trim and unscrew it, it'll pull out and you can disassemble it completely from there.
Old Feb 28, 2004 | 06:22 PM
Spider Man's Avatar
Default Re: replacing inside door handles.....how hard? (fluxion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fluxion &raquo;</TD></TR><TR><TD CLASS="quote">
i've replaced two handles on my 5th gen, i'm not sure how much different it is for a 4th gen, but in my case removing the door panel wasnt even necessary. you just pop a little cover off the handle trim and unscrew it, it'll pull out and you can disassemble it completely from there.</TD></TR></TABLE>
Someday I would like to know WHY people do that.
Whenever I am in somebody elses car I always wait till they are ready to leave the car before I go for the handle.
I'ts just polite.
Old Feb 29, 2004 | 07:42 AM
92hondaex's Avatar
spiderman how hard is it to fix the antenna? Mine is stuck up.
What goes wrong with these....the motor....?
Old Feb 29, 2004 | 11:39 AM
Spider Man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondaex &raquo;</TD></TR><TR><TD CLASS="quote">spiderman how hard is it to fix the antenna? Mine is stuck up.
The motor is not hard to fix.
When you say stuck is the motor still running?
Old Feb 29, 2004 | 01:38 PM
The_Todd's Avatar
Farts in the shower
If your mast is just broken and your motor is still running just remove the mast holder (the circle thing on the base of the mast connected to the car). Then before you eed in the new mast line to the motor just have someone turn on the radio or something to trigger the motor to start running and it will at first raise the mast and then turn the radio off....this will cause the motor to go into the "lowering" phase and start feeding the mast in. Put the mast holder back on and viola...a 5 minute job . As far as the door handles to anyone who trys to pry the door open before the door is unlocked (its not a ******* ford). Its just a matter of removing the cap behind the handle and unscrew it and pop it off...chiltons ownZ!
Old Feb 29, 2004 | 07:11 PM
92hondaex's Avatar
I don't think the motor runs at all. I never really listened for it. All I know is that the antenna is always up.
Old Mar 1, 2004 | 01:33 AM
Spider Man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondaex &raquo;</TD></TR><TR><TD CLASS="quote">I don't think the motor runs at all. I never really listened for it. All I know is that the antenna is always up.
Listen for the motor.
If it runs then replace the mast.
If it is dead, try to get another OEM part and just plop it in.
2003CivicLx
Sep 18, 2008 05:14 PM
lax1089
Feb 3, 2007 05:50 PM
97RSTEG
Jul 11, 2006 08:05 AM
EvilKnightsport
Aug 22, 2005 06:01 PM
PhucNguyen57
May 7, 2003 01:09 PM
