Removing valve springs
Where do you get the tool to remove HONDA valvesprings? I bought a MAC one, but the DOHC design doesn't allow enough clearance for the tool to clamp the spring from both sides. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c jackson »</TD></TR><TR><TD CLASS="quote">why not do that? thats how i do it...never had a problem. just gotta watch where the keepers fly to.</TD></TR></TABLE>
Yeah that's how I've done mine too! Just put some rags under the valves. Easy toget them off this way and no damages, I was told by a machine shop to do it this way also, it's easier than using the tool.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Claborn »</TD></TR><TR><TD CLASS="quote">thats a good way to get em off.... but how do you get em back on??</TD></TR></TABLE>
With the correct tool!!! Sheesh! Where's the hammer?
Yeah, I kmow it's easy to get them off- but getting them back on without the tool is the trick. Figured I'd just get the RIGHT tool in beginning-
Guest
Posts: n/a
actualy.. i just use steel tensil wire, and wrap them around the valves, to put them back on. Compress it with some tape and a adjustable wrench, then wrap the coils togther. slides right on, then just clip each string till it goes up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RAWB »</TD></TR><TR><TD CLASS="quote">Where do you get the tool to remove HONDA valvesprings? I bought a MAC one, but the DOHC design doesn't allow enough clearance for the tool to clamp the spring from both sides. Thanks
Snap-on makes a nice DOHC valvespring compressor system that works on most any motor. Its pricey, but works pretty damn well for holding constant pressure on springs and trying to fit in retainers.
</TD></TR></TABLE>Snap-on makes a nice DOHC valvespring compressor system that works on most any motor. Its pricey, but works pretty damn well for holding constant pressure on springs and trying to fit in retainers.
ltho1998
Aug 3, 2003 05:45 PM
