how to tell if turbo is bad?
Old Feb 27, 2004 | 09:59 AM
egturbo's Avatar
Default how to tell if turbo is bad?
hello. i dont know if its my turbo but my car is blowin white sometimes blue smoke at idle and while drivin. and its makin me sick. its a fresh rebuilt d16y8. i even took out the fmu cuz i thought it was running rich. still smokin. do i need a new 15g turbo? i have a sohc greddy kit. will a bad turbo ruin my motor?
also what other turbo would fit the sohc manifold and downpipe? can i upgrade to 18g?
any help will be appreciated thanks and if anyone got a 15g for sale in good condition let me know thanks.
Old Feb 27, 2004 | 01:33 PM
b18bturbo's Avatar
Default Re: how to tell if turbo is bad? (egturbo)
you can do some quick checks first check downpipe for oil if so its blowing through your seals.
second you can check shaft play of the turbo try moving the shaft up adn down left or right if its feels loose time for rebuild
Old Feb 27, 2004 | 01:50 PM
egturbo's Avatar
can it be my fuel pump?
Old Feb 27, 2004 | 02:40 PM
egturbo's Avatar
CAN THE SMOKE BE BECAUSE OF A KINK IN THE FUEL LINE THAT GOES INTO THE FUEL FILTER? I BROKE THAT PIECE AND HAD TO CUSTOM A NEW ONE AND IT HAS KIND OF A KINK IN IT. CAN IT BE THAT? I CAN TAKE PICS.
Old Feb 27, 2004 | 02:49 PM
boostn420's Avatar
No sounds like a turbo problem more than a fuel problem. If it were a kinked fuel line problem it would be lean not rich. Make sure the return line flows good and check the down pipe for oil.
Old Feb 27, 2004 | 03:05 PM
CRX T-Si's Avatar
Default Re: how to tell if turbo is bad? (boostn420)
Make sure you do a compression check first then you would know more.
Old Feb 27, 2004 | 06:33 PM
SIK IN DA HED's Avatar
New User
check your turbo first... signs of oil leaks is definitely the problem.
Old Feb 28, 2004 | 08:54 PM
egturbo's Avatar
Default Re: (SIK IN DA HED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIK IN DA HED &raquo;</TD></TR><TR><TD CLASS="quote">check your turbo first... signs of oil leaks is definitely the problem.
man thats so much work.. but damn i checked my spark plugs today and damn their black like a ****. still smokes sooo much. but im not losing oil wtf? but i freakin lost more than half a tank of gas in just like 20 miles. wtf is that all about? i have stock injectors with fmu and fuel pump
Old Feb 28, 2004 | 10:18 PM
kyosoeg6's Avatar
Default Re: (egturbo)
is your oil all black or does it look milky. everytime ive blown a head gasket ive lost mad gas and coolant
Old Feb 28, 2004 | 10:46 PM
egturbo's Avatar
Default Re: (kyosoeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyosoeg6 &raquo;</TD></TR><TR><TD CLASS="quote">is your oil all black or does it look milky. everytime ive blown a head gasket ive lost mad gas and coolant</TD></TR></TABLE>
its a brand new fresh completly rebuilt motor.
Old Feb 29, 2004 | 03:54 AM
Nid Styles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbo &raquo;</TD></TR><TR><TD CLASS="quote">
man thats so much work.. but damn i checked my spark plugs today and damn their black like a ****. still smokes sooo much. but im not losing oil wtf? but i freakin lost more than half a tank of gas in just like 20 miles. wtf is that all about? i have stock injectors with fmu and fuel pump</TD></TR></TABLE>
UHH? Check your coolant first, and then your oil. Who built this engine?
Let us know what you see, after that.
Old Feb 29, 2004 | 10:12 AM
egturbo's Avatar
Default Re: (nd_styles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nd_styles &raquo;</TD></TR><TR><TD CLASS="quote">
Let us know what you see, after that. </TD></TR></TABLE>
imma take out my turbo kit today. gonna check the turbo see if its leakin oil out.
Old Feb 29, 2004 | 04:09 PM
egturbo's Avatar
ok took my whole turbo kit off. my turbo is in the best shape it can be. no shaft play at all side to side in and out. put back my stock headers and took out walbro fuel pump and fmu no more smoke. my sohc turbo kit is now for sale.
Old Feb 29, 2004 | 04:34 PM
brickonwheels's Avatar
don't give up!!!
Old Feb 29, 2004 | 04:42 PM
egturbo's Avatar
Default Re: (brickonwheels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brickonwheels &raquo;</TD></TR><TR><TD CLASS="quote">don't give up!!!</TD></TR></TABLE>
im sorry boys goin back to b series.
Old Feb 29, 2004 | 05:18 PM
Chillinit's Avatar
...comon dude...don't get that discouraged!!
Old Feb 29, 2004 | 05:26 PM
egturbo's Avatar
Default Re: (Chillinit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit &raquo;</TD></TR><TR><TD CLASS="quote"> ...comon dude...don't get that discouraged!!</TD></TR></TABLE>
sorry. im pretty sad also. rebuilt my whole motor took about two months to get my car back drove it 20 miles and now im sellin. im pretty pissed. wiring harness given me problems. im just gonna go back to b series. here's the thread i made on my sale. sucks man i really wanted to stay sohc. thats y i sold my b18 turbo before. but the dohc motor was easier on me. for some reason.
https://honda-tech.com/zerothread?id=783807
Old Feb 29, 2004 | 07:07 PM
CRX T-Si's Avatar
I know that you said it's freshly rebuilt but did you bother to the compression check???
Old Feb 29, 2004 | 07:14 PM
soundman's Avatar
Your map could be reading incorrectly or possiblitly that your O2 sensor isnt reading right... Sounds like a fuel problem... Did you check all your vacuum lines and lsten for any sucking noises?
Old Feb 29, 2004 | 07:21 PM
egturbo's Avatar
Default Re: (soundman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundman &raquo;</TD></TR><TR><TD CLASS="quote">Your map could be reading incorrectly or possiblitly that your O2 sensor isnt reading right... Sounds like a fuel problem... Did you check all your vacuum lines and lsten for any sucking noises?</TD></TR></TABLE>
motor is good no more smoke. put my motor back to stock motor is good. turbo is hella good. it was runnin too rich for some reason. i didnt know how to tune my vafc and my dx ecu was burnt. i dunno i wanna go back to b series. thats y im sellin all my good sohc stuff.
ChrisCrankz96
May 3, 2013 06:34 AM
sohc_turd
Mar 1, 2006 11:48 AM
Quad-Damag
Sep 28, 2003 08:05 PM
etmoron
Sep 19, 2003 05:10 PM
APEX i GSR
Aug 24, 2003 12:58 PM
