Synthetic or not?
Old Feb 25, 2004 | 08:41 PM
ZTYPE_S's Avatar
Default Synthetic or not?
alright, i'm tierd of getting a billion answers on why not to use synthetic and why its better to use synthetic...i have a 2003 with about 13k miles on it, would it be best to just stay with synthetic, or go with castrol gtx? some people i've spoken with tell me that synthetic oil isnt good and some say its GOOD, can someone give a concrete answer? thanx
-2003 rsx type-s
-bone stock w/ nuespeed intake
Old Feb 25, 2004 | 08:53 PM
kseriesDC5's Avatar
Default Re: Synthetic or not? (ZTYPE_S)
all i know is.. that i am gonna run syn when im around 9k miles. Syn helps engine when its running hard, and helps it last longer
Old Feb 25, 2004 | 09:00 PM
Perception's Avatar
synthetic really isn't needed as long as you change your motor oil regularly. The thing with synthetic is it doesn't break up as much as dino oil, and is good if you dont change your oil every 5-7k miles.
Old Feb 26, 2004 | 08:48 AM
scribnits's Avatar
Default Re: Synthetic or not? (southwego)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by southwego &raquo;</TD></TR><TR><TD CLASS="quote">synthetic really isn't needed as long as you change your motor oil regularly. The thing with synthetic is it doesn't break up as much as dino oil, and is good if you dont change your oil every 5-7k miles.</TD></TR></TABLE>
This isnt 100% true. While you are correct about synthetic not breaking down as soon, it really does make a difference in the way the motor runs. Synthetic oil reduces friction much more than conventional oils, therefore allowing the motor to run harder and more effiecent. I recently switched from regular to Castrol Syntec 5w30, at about 9600 miles, and Im very happy so far...the car actually does seem to run a little harder and smoother (to me at least).
Old Feb 26, 2004 | 03:17 PM
Eee Pee's Avatar
Default Re: Synthetic or not? (Driftntouge)
These are touchy topics.
I can tell you synthetics are a better oil than a regular oil.
The thing is, a regular oil is pretty damn good these days.
Better regular oils can do 5K no problem.
I've tried a bunch of different oils in the race car which has a D16 in it.
For a regular oil, I can tell you Pennzoil's high mileage is excellent.
However, I was caught up in the new German Castrol 0w-30 hoopla buzz, so that's what's in there now.
But nowadays, Honda is recommending a lighter weight.
So, that leads me to HIGHLY recommend Mobil 1's 0w-20 oil.
It'll last ~10k miles. It'll hold up for that long too.
Add a Honda OEM S2000 filter made by Toyo Roki, you're very good to go.
You'll need more than 5 quarts though (which is good, too).
Old Feb 26, 2004 | 03:24 PM
f1nal zeros's Avatar
I have ran Redline Synthetic oil in my car since it's first oil change when the car had 4k miles on it. Now I change the Syn every 4k miles and the car is running strong and hard. No problems with it so far and I have around 63k miles on it now.
No matter which oil you choose weather it be syn or regular oil it will do the job right.
Old Feb 26, 2004 | 03:39 PM
CHILIBEANZ's Avatar
i've been running valvoline vr1 racing oil(conventional) 10w30 since the turbo was put in. excellent oil, comes out just as good as when it goes in.
Old Feb 26, 2004 | 05:23 PM
cjump85's Avatar
Default Re: (p220)
im coming up on that first oil change (3,000). should i go a couple more before synthetic or is it safe to switch now.
Old Feb 26, 2004 | 06:27 PM
ekferio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driftntouge &raquo;</TD></TR><TR><TD CLASS="quote">This isnt 100% true. While you are correct about synthetic not breaking down as soon, it really does make a difference in the way the motor runs. Synthetic oil reduces friction much more than conventional oils, therefore allowing the motor to run harder and more effiecent. I recently switched from regular to Castrol Syntec 5w30, at about 9600 miles, and Im very happy so far...the car actually does seem to run a little harder and smoother (to me at least).</TD></TR></TABLE>
isn't castrol syntec not a true synthetic oil? i've read that somewhere before. Everyone was using mobil one
Old Feb 27, 2004 | 10:30 AM
scribnits's Avatar
Default Re: Synthetic or not? (ekferio)
Its a synthetic blend, not a full synthetic (I think). So far, it seems to be much better than GTX Drive Hard, which is what Ive been using for years. Im thinking about trying out Motul, its not that much more than Redline.
Old Feb 28, 2004 | 01:15 AM
ecsahs3's Avatar
Last year, I told the dealer to put in synthetic and the advisor said I should wait till 30k miles. This will allow proper time for the engine to break in and proper valve seating, blah blah blah. He said I was doing good by changing the oil every 3k miles. I'm not sure about the 30k mile reasons, but if he's not trying to sell it to me, then I'm sure he knows what he's talking about.
Old Feb 28, 2004 | 02:34 PM
darkvibe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driftntouge &raquo;</TD></TR><TR><TD CLASS="quote">Its a synthetic blend, not a full synthetic (I think). So far, it seems to be much better than GTX Drive Hard, which is what Ive been using for years. Im thinking about trying out Motul, its not that much more than Redline.</TD></TR></TABLE>
Castrol makes syntec (full synthetic) as well as syntec blend (mix of synthetic and dino). It says blend right on the bottle if thats what you have.
Old Feb 28, 2004 | 07:54 PM
SloazzEKhatch's Avatar
Default Re: Synthetic or not? (darkvibe)
anyone have any thoughts on mobile one 5-30? that is what i use...
Old Feb 29, 2004 | 07:43 AM
Eee Pee's Avatar
Default Re: Synthetic or not? (SloazzEKhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloazzEKhatch &raquo;</TD></TR><TR><TD CLASS="quote">anyone have any thoughts on mobile one 5-30? that is what i use...</TD></TR></TABLE>
All of Mobil 1 oil is a great oil.
There is some burn off, and it's normal.
A lot of Hondas burn oil regardless of their condition.
I'm found of their 0w-20 oil right now.
The Used Oil Analysises posted on oil discussion boards are always excellent.
Some say 0w-20 is too thin, but they should read up more on this stuff.
It show little, to no wear metals in the oil after ~7500 miles.
Old Feb 29, 2004 | 09:28 AM
darkvibe's Avatar
Default Re: Synthetic or not? (Eee Pee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eee Pee &raquo;</TD></TR><TR><TD CLASS="quote">
It show little, to no wear metals in the oil after ~7500 miles.</TD></TR></TABLE>
I use 0-20 also. I switched to it at my 15,000 mile oil change.
Old Feb 29, 2004 | 03:10 PM
so if you had 32K on your EP would you switch to the 0-20W?
Old Feb 29, 2004 | 04:22 PM
ITR_1211's Avatar
Default Re: (cjump85)
Mobil 5W30
Old Feb 29, 2004 | 05:26 PM
delslow94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloazzEKhatch &raquo;</TD></TR><TR><TD CLASS="quote">if you had 32K on your EP would you switch to the 0-20W?</TD></TR></TABLE>
Yes.
Go to http://www.bobistheoilguy.com and do a little reading on the forums, and do a search for Mobil 1 or whatever.
SiReflex
Jul 4, 2007 08:50 PM
LSintegra
Jan 12, 2006 02:46 PM
coupon
Aug 28, 2005 12:19 PM
B18cteg
May 29, 2003 05:09 PM
Bbasso
Apr 22, 2003 03:55 PM
