is 3000 to early
Old Aug 27, 2005 | 08:22 AM
coupon's Avatar
Default is 3000 to early
is 3000 miles to early to change your oil on a built/boosted car?
Old Aug 27, 2005 | 08:51 AM
beerbongskickass's Avatar
Default Re: is 3000 to early (coupon)
That's way too late. I am using regular Castrol GTX 10w30 and I change my oil every 1000 miles or so. If your using synthetic oil you could wait longer between oil changes though. Just do a little searching man.
Old Aug 27, 2005 | 04:42 PM
coupon's Avatar
Default Re: is 3000 to early (beerbongskickass)
im using mobil1 10w30 synthetic
Old Aug 27, 2005 | 04:44 PM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">That's way too late. I am using regular Castrol GTX 10w30 and I change my oil every 1000 miles or so. If your using synthetic oil you could wait longer between oil changes though. Just do a little searching man.</TD></TR></TABLE>
why not just use synth? isnt it a pita to change it every 3 weeks?
Old Aug 27, 2005 | 05:20 PM
boosted92's Avatar
Default Re: is 3000 to early (m R g S r)
I use valvoline non synthetic and change it every 3K. 10W40. I don't see any reason to change your oil every 1000 miles, that's every two weeks or less for me.
Coupon: If you can afford it, there arn't any downfalls to changing your oil "too early". 3000 miles is the recommended change interval for pretty much any car made, so that's what I'd do.
Old Aug 27, 2005 | 05:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
why not just use synth? isnt it a pita to change it every 3 weeks?</TD></TR></TABLE>
I don't drive that many miles everyday, so I don't really change it that often. I will usually just change it before I go to the track or street racing if it has been a while. Plus I have s shitty t3 turbo that I don't care about on a stock motor. When I get a ball bearing turbo and a built motor then I will run synthetic.
Old Aug 27, 2005 | 05:39 PM
coupon's Avatar
Default Re: is 3000 to early (boosted92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">I use valvoline non synthetic and change it every 3K. 10W40. I don't see any reason to change your oil every 1000 miles, that's every two weeks or less for me.
Coupon: If you can afford it, there arn't any downfalls to changing your oil "too early". 3000 miles is the recommended change interval for pretty much any car made, so that's what I'd do.</TD></TR></TABLE>
yeah true, but how long would be the longest to wait while still really getting the full use out of it
Old Aug 27, 2005 | 07:44 PM
Dunc's Avatar
BCICAN
there is no such thing as too early. Basically your oil is dirty after you start the car the 1st time. Depends how hard you drive it....but I wouldn't wait for 1 mile over 3000.
Old Aug 28, 2005 | 12:41 AM
paopao's Avatar
Default Re: is 3000 to early (Dunc)
When VTEC stops kicking in, I change my oil .
Old Aug 28, 2005 | 08:44 AM
T4eg's Avatar
Default Re: is 3000 to early (paopao)
i change the oil in my turbo car every week. maybe 2 times depending if i run it at the track or not. normal castrol 20w50 and honda oil filters
Old Aug 28, 2005 | 08:54 AM
Suprdave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paopao &raquo;</TD></TR><TR><TD CLASS="quote">When VTEC stops kicking in, I change my oil .</TD></TR></TABLE>
Smart Paolo
Old Aug 28, 2005 | 09:03 AM
95GSRTT
Guest
Posts: n/a
Default Re: is 3000 to early (Suprdave)
every 1000 miles? Maybe Im a cheap *** but that just seems overly excessive to me.
Old Aug 28, 2005 | 10:10 AM
paopao's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">Smart Paolo</TD></TR></TABLE>
I learn from the best.
Old Aug 28, 2005 | 12:19 PM
Sohc Driver's Avatar
I change my oil and filter every 2500 miles. Mobil1 Synthetic 10w30 and OEM Honda Filters
p3terson17
Honda Civic (2006 - 2015)
30
Jan 21, 2009 08:12 PM
d3xt3r19
Dec 5, 2007 05:30 PM
SiReflex
Jul 4, 2007 08:50 PM
peel17
Jun 28, 2005 01:10 PM
mickey513
Oct 5, 2001 10:11 AM
