Jet Force and V-AFC, ANY GOOD
Old Oct 13, 2001 | 05:06 AM
migo's Avatar
New User
Default Jet Force and V-AFC, ANY GOOD
Fellas, What do you think about the Jet Force Ignition Module. If it helps you out with the Igniition ttiming through out the whole power band, that would be my next investment.
Think about it, When setting the Ignition timing on the Flywheel helps out at Idle, but once the revs goes up, It goes out of range, with the Jet Force and my V-AFC the would be a great investment
Old Oct 13, 2001 | 05:47 AM
JG Luder's Avatar
Default Re: Jet Force and V-AFC, ANY GOOD (D.specs)
VAFC: Talk is cheap. Just buy it.
Old Oct 13, 2001 | 10:16 AM
migo's Avatar
New User
Default Re: Jet Force and V-AFC, ANY GOOD (JG Luder)
Why do you criticize the subject, are you scared I'm hunting you down.
By the way, NO JOKE, what's going on with you motor. Ever found out the problem
Old Oct 13, 2001 | 10:18 AM
JG Luder's Avatar
yeah. I don't have compression in two cylinders like I should. As soon as I get my ECU back from Prospeed (who claims his programmer is down and that's why he's had it for over a month) then I can start driving it and trying to finish breaking the rings in.
Do that, hit the dyno for some tuning, grab a new tranny, and I'm set.
Old Oct 13, 2001 | 10:31 AM
migo's Avatar
New User
They say 1000 miles break-in period, I say after 1000 miles is over give it another 1000 miles on / off regular driving, because It really takes more mileage for a true break-in, just my words of wisdom.
Every body has there own opinon
Old Oct 13, 2001 | 10:34 AM
JG Luder's Avatar
well, my words are don't run that mother rich when it's breaking in.
Old Oct 13, 2001 | 05:15 PM
migo's Avatar
New User
I've learned that the hard way.............. cause now I'm re-building my bottom end. But this time Stronger
dmxsoulja3
Mar 13, 2005 02:49 PM
civictypenos
Aug 24, 2003 08:30 AM
uNF$@#!
May 12, 2002 10:57 PM
HX_Guy
Jan 20, 2002 05:40 PM
ITR 01-0840
Jan 7, 2002 04:59 PM
