question about LS and B20 motors
Old Feb 23, 2004 | 04:36 PM
XEF-9X's Avatar
Default question about LS and B20 motors
Well I got a smog ref ticket and im considering my options here.
I am aware that I can use all del sol vtec parts and make my JDM b16 pass under the assumption that the smog ref believes that im running a del sol vtec. But I dont really want to spend the money to make it all legit and then have him tell me to go **** myself. So Ive always wanted a LS/Vtec, or B20/Vtec. I am considering just getting an LS motor switching to OBD1 if need be and passing that way. But I would prefer a b20. I forsee a problem though , Obviously a b20 ecu will not work because they only come in automatic. WHat options would have ecu wise with a b20 in order for it to pass smog ref inspection if any???
is it possible to use a usdm LS ecu with a b20?
or any other usdm 5spd bseries ecu?
Old Feb 23, 2004 | 07:13 PM
XEF-9X's Avatar
Default Re: question about LS and B20 motors (XEF-8X)
bump
Old Feb 23, 2004 | 07:36 PM
MADEINIRAQ's Avatar
b20 came in manual
Old Feb 23, 2004 | 07:37 PM
ThefirstPACT's Avatar
you need to search. there are 5 SPEED crv's! You can use plenty of ECU"S to make what you want work!!!
Old Feb 24, 2004 | 04:35 AM
haggar's Avatar
Default Re: question about LS and B20 motors (ThefirstPACT)
yeah, only the 97s were auto only, I believe... 98 gained 5 speeds, and 99 got higher horsepower/compression..
Old Feb 24, 2004 | 06:49 AM
XEF-9X's Avatar
Default Re: question about LS and B20 motors (haggar)
thats awesome! I need a usdm ecu to pass smog ref inspection. How hard is it to find a 5 speed b20 ecu usdm??? and how much?
Old Feb 24, 2004 | 06:59 AM
tommyL's Avatar
The ref won't pass a b20 'cause it's considered a light truck motor.
A properly installed LS motor with the appropriate emissions equipment can pass with an obd1 conversion and an obd1 LS ecu.
You can get a vtec head and ecu later. Good luck.
Old Feb 24, 2004 | 02:44 PM
XEF-9X's Avatar
Default Re: question about LS and B20 motors (tommyL)
anyone know of a good place to get a usdm ls ecu?
I will prolly just get a jdm ls motor and tranny but i still need a usdm ls ecu? what do they normally run for ahd where is a good source to get one from?
Old Feb 24, 2004 | 02:59 PM
Deetz's Avatar
Crazy Honda Guy
I can help you out with one, as i have an extra now that i will be running a B18C5 instead of an LS set up.
If interested, e-mail me direct dieter@customauto.ca
Deetz
Russyo
Jan 30, 2012 06:39 AM
93hatch_minime
13
Apr 21, 2009 12:08 AM
poppypizza
Nov 8, 2007 07:48 PM
IwantmyEG
Mar 14, 2005 09:15 AM
ALLMOTA92EG
Feb 6, 2005 11:28 PM
