b16a2 or b18b will boost better?
Old Feb 23, 2004 | 03:13 PM
Bictorious's Avatar
Default b16a2 or b18b will boost better?
which of these motors are better to boost?
Old Feb 23, 2004 | 03:39 PM
drvfast's Avatar
Default Re: b16a2 or b18b will boost better? (Bictorious)
I like both ls motors and b16's. Its a personal opinion the b18 can handle more boost because of lower compression. The reason i like b16's more is because this motor has a better flowing head, higher redline and can spool bigger turbo and make power because of the higher compression. Its a little harder to tune due to higher compression, but like i stated earlier its up to the person.
Old Feb 23, 2004 | 03:53 PM
TurboJesse
Guest
Posts: n/a
Default Re: b16a2 or b18b will boost better? (airshifta)
surch
Old Feb 23, 2004 | 04:29 PM
BoostedSi's Avatar
Default Re: b16a2 or b18b will boost better? (Mpir3)
theres like 50+ threads on this at least....
Old Feb 23, 2004 | 04:35 PM
b18b1hmtlove's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by airshifta &raquo;</TD></TR><TR><TD CLASS="quote">I like both ls motors and b16's. Its a personal opinion the b18 can handle more boost because of lower compression. The reason i like b16's more is because this motor has a better flowing head, higher redline and can spool bigger turbo and make power because of the higher compression. Its a little harder to tune due to higher compression, but like i stated earlier its up to the person.</TD></TR></TABLE>
that is really well said. also i should mention that the b18 will have a lower amount of hp but the tq will almost be matching while with the b16 you will get more whp but a much lower amount of tq.
slowcrx954
Nov 23, 2006 07:49 AM
ivebenjamin
Feb 2, 2006 11:34 PM
Black R
Mar 20, 2005 03:24 PM
RooskiGSR
Feb 28, 2005 04:23 PM
Feuerraeder
Feb 23, 2002 09:11 PM
