b16a2 or b18b will boost better?
I like both ls motors and b16's. Its a personal opinion the b18 can handle more boost because of lower compression. The reason i like b16's more is because this motor has a better flowing head, higher redline and can spool bigger turbo and make power because of the higher compression. Its a little harder to tune due to higher compression, but like i stated earlier its up to the person.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by airshifta »</TD></TR><TR><TD CLASS="quote">I like both ls motors and b16's. Its a personal opinion the b18 can handle more boost because of lower compression. The reason i like b16's more is because this motor has a better flowing head, higher redline and can spool bigger turbo and make power because of the higher compression. Its a little harder to tune due to higher compression, but like i stated earlier its up to the person.</TD></TR></TABLE>
that is really well said. also i should mention that the b18 will have a lower amount of hp but the tq will almost be matching while with the b16 you will get more whp but a much lower amount of tq.
Black R
Mar 20, 2005 03:24 PM
RooskiGSR
Feb 28, 2005 04:23 PM
