Is there supposed to be a gasket in between the turbo and turbo manifold on the drag III kit? cuase
Old Oct 12, 2001 | 02:41 PM
chuckd05's Avatar
New User
Default Is there supposed to be a gasket in between the turbo and turbo manifold on the drag III kit? cuase
Is there supposed to be a gasket between the turbo and the turbo manifold? I know my kit didnt come with one i was just making sure.
Old Oct 12, 2001 | 02:52 PM
TurboInteg95's Avatar
Default Re: Is there supposed to be a gasket in between the turbo and turbo manifold on the drag III kit? cu
yeah actually there is a gasket that goes between the turbo and the manifold. There's no gasket between the turbo and the DP though.
Old Oct 12, 2001 | 03:01 PM
JM Performance's Avatar
I've actually heard that for connections where both materials are the same heat (manifold to turbo / turbo to dp), your better off w/o a gasket and just using two perfectly flat surfaces.
But I'm not sure what the DRAG kit is supposed to have.
Old Oct 12, 2001 | 03:03 PM
DragII's Avatar
25 Year Member
no DRAG does not supply one.....at least I never got one
Old Oct 12, 2001 | 03:35 PM
GruvyTune's Avatar
New User
fmax doesn't either. They recommend the copper high temp gasket material between all such mating surfaces.
Old Oct 12, 2001 | 04:06 PM
dustin's Avatar
I used an HKS T3 gasket. Worked great.
Dustin
Old Oct 12, 2001 | 04:07 PM
b18bvudoo's Avatar
New User
great...something else i gotta get
Old Oct 12, 2001 | 04:11 PM
dustin's Avatar
It is not 100% necessary, but I wanted to make sure I had no exhaust leaks.
Dustin
Old Oct 12, 2001 | 04:15 PM
DragII's Avatar
25 Year Member
anyone ever used high temp gasket maker...like you use on the oilpan? seems like that would work pretty good.
Old Oct 12, 2001 | 04:17 PM
dustin's Avatar
I still think the turbo/manifold gets too hot for that stuff. You need a metal gasket.
Dustin
Old Oct 12, 2001 | 04:22 PM
DragII's Avatar
25 Year Member
hmm prolly right there
Old Oct 12, 2001 | 04:24 PM
Adi Radoncic's Avatar
On Fire!
Dustin is right!!! I got mine from HKS for about $25.
Old Oct 12, 2001 | 05:35 PM
DLB1994's Avatar
u can go to a saab dealer and get one i did they have t3's to i payed 12 bucks
Old Oct 12, 2001 | 06:03 PM
DirtyLude's Avatar
These guys sell, both a T3 turbine inlet gasket ( $8 ) and a t3 turbine exhaust gasket ( $15 ).
http://www.roadraceengineering.com/f...andgaskets.htm
Old Oct 12, 2001 | 06:48 PM
Hispeed's Avatar
just go to your nearest parts store and get a turbo gasket for a 86 ford thunderbird. Works like a charm and is CHEAP!!!
Old Oct 17, 2001 | 12:30 PM
98lude's Avatar
Just want to share this with you guys, I bought mine from Turbonetics themselves, and it is only 3.70. looks exactly like the one in roadraceengineering.
Old Oct 17, 2001 | 02:37 PM
redline's Avatar
I got a nice metal one from the first turbo 300zx
93grayeg
Sep 11, 2024 07:33 PM
R-1303
May 19, 2002 03:09 PM
JMinSi2000
Mar 27, 2002 08:13 PM
HXMan
Dec 17, 2001 04:20 PM
wwcivic
Sep 3, 2001 05:45 PM
