No gaskets with drag 3 kit?
Old Dec 17, 2001 | 12:00 PM
HXMan's Avatar
Default No gaskets with drag 3 kit?
My kit didn't come with a manifold to turbo gasket, or a turbo to downpipe gasket...also, no exhuast manifold gasket.
What should I use for the manifold...an OEM gasket? And what about the turbo gaskets? What to use there?
Thanks,
Levi
Old Dec 17, 2001 | 12:19 PM
IVANITR's Avatar
Default Re: No gaskets with drag 3 kit? (HXMan)
I used my oem exhaust manifold gasket. As far as the gaskets for turbo to manifold and downpipe to turbo, drag does not have any for them.
Old Dec 17, 2001 | 12:33 PM
Flamenco-T's Avatar
for turbo to manifold, buy a T3 gasket from ford, audi dealership or try turbonetics.com or majestic turbo.
no gasket needed between downpipe and turbo
exhaust manifold gasket use honda OEM
Old Dec 17, 2001 | 12:47 PM
Speed PHreak's Avatar
Default Re: No gaskets with drag 3 kit? (Flamenco-T)
Red RTV high temp gasket maker will work in a pinch. Dunno how long it will hold up, but i'm running it on mine and hoping that I don't have to F' with it
Old Dec 17, 2001 | 12:56 PM
HXMan's Avatar
Thanks for the replys!
Old Dec 17, 2001 | 01:12 PM
chri5's Avatar
i have no gasket between either the manifold and turbo or the turbo and DP. It sure doesnt seem to leak.
Old Dec 17, 2001 | 01:28 PM
Flamenco-T's Avatar
Default Re: No gaskets with drag 3 kit? (Strng1dah)
true, the carbon should seals all the cracks and leaks...
as long as you have a flat and clean surfaces, gasket are not really needed...
stan
Old Dec 17, 2001 | 01:42 PM
Tomakit's Avatar
I never ran a gasket between mani and turbo, never had a leak either.
I tried to run a gasket between the mani and wastegate, but melted that one. So ever since I just went raw. No leaks to speak of.
Tom
Old Dec 17, 2001 | 02:46 PM
bottlefedb18c1's Avatar
Default Re: No gaskets with drag 3 kit? (Speed PHreak)
i just reused my manifold gasket and used no gasket anywhere else other then the one for the wastgate and i dont have any problems with it yet
Old Dec 17, 2001 | 03:05 PM
HXMan's Avatar
Default Re: No gaskets with drag 3 kit? (turbogsrb18c1)
Good to hear all this!
Old Dec 17, 2001 | 04:20 PM
boosted hybrid's Avatar
When I installed both my friends Fmax and Drag kits they didnt include the gaskets for the turbo-to-manifold or the turbo-to-downpipe. Now I realize the the turbo-to-downpipe gaskets are not needed, but I am the type of person that likes like use gaskets everywhere I can. We bought all the gaskets that we needed at http://www.roadraceengineering.com. BTW, high temp RTV does leak after awhile. We used some on my friends Drag install and we had a exhaust leak about a month later...just sucks to unbolt everything to install a gasket.
2000__GSR
Jun 15, 2004 05:31 AM
R-1303
May 19, 2002 03:09 PM
wwcivic
Sep 3, 2001 05:45 PM
