gasket needed between turbo and turbo manifold?
Hey guys just pulled my pte6262 off my car and there was no gasket between the turbo manifold and the turbo? Is this a common thing? Should I order a gasket or leave it as it? The flange on the turbo has a lot of black exhaust soot on it which looks to me like it would of been leaking?? Any help would be great
Who is Mr Robot?
Re: gasket needed between turbo and turbo manifold?
Normally both flanges are perfectly flat so technically you wouldn't need one, however some companies don't surface flanges after welding so they warp and over time and lots of heat cycles flanges will warp.
I run an mls or copper gasket for peace of mind.
Moderator
^^^Hehe. I used to refuse to repair turbos that had this stuff on there. Especially the Drifter guys and their monkey-made turbos. Soon as I saw some copper gasket, I knew i was in for trouble with the rest of the internals.
These aren't even $10.. really?!? Folks are that f#$kin' lazy and cheap, nowadays?
both my manifolds came with the steel gasket even the ebay. one guy swears by rtv and no oil restrictor doesnt mean its better haha
you don't need a gasket. Torque it to the manifold correctly, and fire it up. If both surfaces are flat, it should be fine. When I first started my build I thought I needed it too. buy a gasket if youre leaking between the two.
I use that from more than fifteen years, I have never had troubles but I have already had problems with gasket of all kinds..
just to put very little of paste.
O god Mac, I hope that isn't the stuff you though I used on the Surfer. I have all appropriate gaskets lol.
Who is Mr Robot?
I use those gaskets in all my builds, nice part is they are 100% reusable unless damaged. They compress and deform very little when installed and torqued.
I also use Mr. Gaskets copper gaskets between the head and manifold. They are also infinitely reusable unless damaged, we use them on the SR20s in our drift cars without a single gasket failure, they also stand up under the torture of numerous repeated tear downs and manifold swaps without fail
Tial sells metal gaskets and most good companies include it and yes you need a gasket. I've never seen a turbo car run correctly without one
