cranking problem
Old Feb 20, 2004 | 01:56 PM
thad
Guest
Posts: n/a
Default cranking problem
here's the situation, the dizzy is bad so i'm not even worried about spark right now, but when i crank it it truns over very slowly and inconsistantly it seems like it's drawing more juice that it should, the battery is dead so i have it jumped, when i crank it the dash lights dim the VAFC turns off and the lights on the car it's jumped to go dim. i tried cranking without the spark plugs in and it its still slow but it is consistant. my compression should be in the ball park of 11.9-12.7:1, the rings have not yet sealed. i can turn it over by hand with just a bit more effort than a stock b16.
Old Feb 20, 2004 | 02:39 PM
RedlinedVTEC's Avatar
Default Re: cranking problem (thad)
I don't really know what you're trying to get at, but you need to do is charge the battery (that's your cause of dimming lights) and replace your distributor.
Old Feb 20, 2004 | 02:54 PM
thad
Guest
Posts: n/a
Default Re: cranking problem (RedlinedVTEC)
perhaps i did not ask a clear question, i'm wondering what might cause the symptoms i described. i'm not trying to make it start right now so the distributor is not an issue, and i jumped the car from a running car with a good battery, i have 12 volts constant while the cables are on.
Old Feb 20, 2004 | 09:43 PM
thad
Guest
Posts: n/a
up
ph0shizzle
28
Oct 2, 2006 10:37 PM
Cooker4418
Aug 30, 2006 07:46 PM
GdmLaz
12
Jun 21, 2005 03:09 PM
thad
Feb 20, 2004 06:16 PM
thad
Feb 20, 2004 02:59 PM
