BIG PROBLEM NEED HELP
K here is the story the car was on idling fine and all of a sudden it just came 2 a brutal stop and stalled out by itself when u try to crank it it does nothing whatsoever just click, click, lol any1 have any idea what this could be
Re: (Slammed92hbonN20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed92hbonN20 »</TD></TR><TR><TD CLASS="quote">if the distributor was bad the car would still crank and if the battery was dead my lights will be dimmed or something </TD></TR></TABLE>
i was saying you didn't describe the problem well enough to give a good answer. the battery can have power and not enough to turn the starter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed92hbonN20 »</TD></TR><TR><TD CLASS="quote">the motor will still crank the motor doesn't crank at all </TD></TR></TABLE>
You just contradicted yourself. The motor cranks but won't start or the motor dosen't crank at all????
Yeah it will still crank if the starter is still good and the dizzy is bad, it will jsut turn and turn but wont start cause there is no spark. Does it sound like the starter is turning the motor over? If it is then battery and starter are still good and it would have to do with the dizzy, fuel system or maybe a blown fuse probably in the engine fuse box. Can you hear the fuel pump prime if you turn it to the second ON position??
