Need to clear some RC 550s!!!
Old Oct 11, 2001 | 05:32 PM
Ben Huynh's Avatar
Default Need to clear some RC 550s!!!
RC 550cc Injectors: $295.00
RC Wire Clips: $40.00
Old Oct 11, 2001 | 05:38 PM
dustin's Avatar
Default Re: Need to clear some RC 550s!!! (ben@importparts.com)
Ah that sucks, I just paid $320 for some used 550 cc injectors
Old Oct 11, 2001 | 05:52 PM
Arturbo's Avatar
Better than steak
25 Year Member
Would that be $335 shipped?
art
Old Oct 11, 2001 | 06:07 PM
Ben Huynh's Avatar
Default Re: Need to clear some RC 550s!!! (Arturbo)
It's $10.00 for shipping but I'll waive it.
Old Oct 11, 2001 | 06:19 PM
Gmedalion's Avatar
Whoooohoooooo, for how long??
Old Oct 11, 2001 | 07:04 PM
DamonBoost's Avatar
New User
Default Re: Need to clear some RC 550s!!! (Gmedalion)
how do you know if you need the clips or not?
Old Oct 11, 2001 | 07:08 PM
The Punisher's Avatar
Default Re: Need to clear some RC 550s!!! (ill logic)
Sorry about that Dustin!
Old Oct 11, 2001 | 07:37 PM
redline's Avatar
if you have a 96+ then you need the clips
what about 720cc injectors ben???
Old Oct 11, 2001 | 07:48 PM
DamonBoost's Avatar
New User
Default Re: Need to clear some RC 550s!!! (redline)
great.. well Ben i will probably be adding this to my order. i will call you tommorow to confirm. ok..
Old Oct 11, 2001 | 08:08 PM
jamal-188's Avatar
How should we pay call you? I want them but I'm still now sure what system I need or should use to run them for a RevHardII/Drag III kit.
Old Oct 11, 2001 | 08:22 PM
VTC_CiViC's Avatar
Bah! I need some 440's dammit!
Old Oct 11, 2001 | 09:55 PM
Pro-Lude's Avatar
Will those work just as good as the 440 recomended w/the hondata or should i stick with 440 that they recomend?
Old Oct 11, 2001 | 10:09 PM
LsTurbo91's Avatar
I second the 720's me want !!
Old Oct 11, 2001 | 11:11 PM
IgniteTeg's Avatar
Default Re: Need to clear some RC 550s!!! (9psiLsT)
What about the RC 440cc Ben??? HOw much is it shipped? Thanks.
[Modified by IgniteTeg, 12:12 AM 10/12/2001]
Old Oct 12, 2001 | 12:47 AM
TurboInteg95's Avatar
Default Re: Need to clear some RC 550s!!! (IgniteTeg)
I third the 720's.
Old Oct 12, 2001 | 05:49 AM
LEON's Avatar
are these direct replacement injectors? I thought 440cc was the largest replacement injectors RC makes for Honda/Acuras? Is this correct and if so does this mean that I would have to run a resistor box?
Old Oct 12, 2001 | 06:10 AM
redline's Avatar
Default Re: Need to clear some RC 550s!!! (LEON)
you are correct
and all you guys wanting 440cc injectors you are far better off in the long run with 550cc or bigger if you are going hondata
DirtyLude's Avatar
440cc is the largest saturated (high resistance) injector that RC makes. You will need either a Hondata with a resistor box to run these, or another ems like SpeedPro/Haltech/DFI.
I just bought brand new 550's from RC without clips for $400.00 about a month ago. Grrrr! Now I need 720's!
Old Oct 12, 2001 | 06:11 AM
Big James's Avatar
New User
OK, so you need clips if you have a 96+, but I have a 97motor with a 94 Wiring Harness. I would say I do not need the clips, correct?
Old Oct 12, 2001 | 06:17 AM
redline's Avatar
Default Re: Need to clear some RC 550s!!! (Big James)
if you are running the 94 injectors that is correct, it is the injectors and clips on the factory harness that are differnet
Old Oct 12, 2001 | 06:22 AM
VTC_CiViC's Avatar
Default Re: Need to clear some RC 550s!!! (DirtyLude)
How so? dbman runs 440's in his car with the stock ECU and an AFC to control the fuel flow so it can idle with those huge 440's.
Old Oct 12, 2001 | 06:30 AM
boosted3g's Avatar
Default Re: Need to clear some RC 550s!!! (VTC_CiViC)
I forth the 720s.
Old Oct 12, 2001 | 06:46 AM
DirtyLude's Avatar
When I said these, I was refering to the 550's. Sorry I didn't make it clearer.
Old Oct 12, 2001 | 06:49 AM
LEON's Avatar
DirtyLude - what PSI are you running that you have maxed out your 550cc injectors? What duty cycle are you running with your 550cc?
Do you think 550cc injectors will be enough to run 12 psi on a Drag Gen III GSR?
Where can you get the resistor boxes?
Old Oct 12, 2001 | 06:51 AM
VTC_CiViC's Avatar
I'd have to think 550's are MORE than enough to supply fuel for a 1.8L. I can see a 2.2L pushing them harder, but 550cc's should go pretty damn far in a B18C at only 12psi. Just my .02 though..
