Normal Tranny Operation?!?
Old Feb 20, 2004 | 06:00 AM
crx_88_si's Avatar
Default Normal Tranny Operation?!?
ok.. 88 CRX si, is the car. stock trans. Centerforce DF clutch w/ lightened OEM flywheel.
I've driven other cars, Ford, Cavs, Neons etc etc..and non exhibit this problem.. however.. never driven another 4g. civic/crx.
While driving I find it IMPOSSIBLE to shift into a LOWER gear unless I rev up the motor. For example... Coming up to a red light.. downshifting from 4 to 3. The shift level WILL NOT go into 3rd gear unless I rev the motor to 3k, is this normal??? This same thing occurs from 3 to 2 shift. 1st gear I cannot get into unless I'm at a COMPLETE stop.
Old Feb 20, 2004 | 07:57 AM
Z6REX-SI's Avatar
That often times is a sign that your synchro's in your tranny are going bad.
Old Feb 20, 2004 | 08:01 AM
crx_88_si's Avatar
Default Re: (Z6REX-SI)
so when you're going 100km/h (60mph) you can push in the clutch and put the car into ANY gear you choose? (of course not letting the clutch out) DAMN!!!!
thx.
Old Feb 20, 2004 | 08:32 AM
tilt's Avatar
Default Re: Normal Tranny Operation?!? (crx_88_si)
you should be able to freely get it into all the gears minus 1st and reverse. 1st should go in relatively easy imo, anywhere between 15-35mph. The problem you describe is similar when my clutch disc broke off a metal bracket. 1st gear pretty much wouldnt go in til a dead stop, grinding when shifting, hard to downshift, occaisional stuttering,occaisional chattering sound, hard to smoothly engage clutch especially 1st gear from a stop.
Old Feb 20, 2004 | 08:41 AM
crx_88_si's Avatar
Default Re: Normal Tranny Operation?!? (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">you should be able to freely get it into all the gears minus 1st and reverse. 1st should go in relatively easy imo, anywhere between 15-35mph. The problem you describe is similar when my clutch disc broke off a metal bracket. 1st gear pretty much wouldnt go in til a dead stop, grinding when shifting, hard to downshift, occaisional stuttering,occaisional chattering sound, hard to smoothly engage clutch especially 1st gear from a stop. </TD></TR></TABLE>
you see thats the funny thing. NO grinding, even at redline shifting. and every other operation of the trans is fine. Reverse will grind if you're not dead stopped but every car does that right? another reason to swap to bseries i guess.
Old Feb 20, 2004 | 11:01 AM
regime's Avatar
you should double clutch to rev match when you down shift neways... i say just learn to do it and not kill yer clutch and syncros
Old Feb 20, 2004 | 11:15 AM
AgentJam's Avatar
Default Re: Normal Tranny Operation?!? (regime)
i hope i don't get laughed at... but what exactly is double clutching?
Vince
Old Feb 20, 2004 | 02:35 PM
CsRiX's Avatar
Default Re: Normal Tranny Operation?!? (AgentJam)
when you are in gear push the clutch in put it in neutral let the clucth out then push the clutch back in and put it in gear.....Hence double clutching......
adam
Old Feb 20, 2004 | 03:10 PM
regime's Avatar
Default Re: Normal Tranny Operation?!? (CsRiX)
what you described what an upshift double clutch. that was used one old cars that didnt have syncros.. now adays its no use... unless you have no 2nd and third gear syncro like me
when you are down shifting double clutching you:
1. hit the clutch
2 put it in neutral
3 let out the clutch
4 rev the engine to the rpm that it would be in the gear you wish to go into.
5 hit the clutch
6 put it into the lower gear.
this saves ware and tear on the clutch and the syncros.
it may sound like it takes some time, but once you get the hang of it, its really easy
Old Feb 20, 2004 | 04:15 PM
AgentJam's Avatar
Cool thanks Regime!
Vince
LvN
Apr 21, 2006 10:00 PM
zracer240
Jul 21, 2005 12:15 AM
5 Skware
Apr 13, 2005 05:04 AM
wickedEFguy
Mar 27, 2005 12:20 PM
