noob question. when does my vtec hits?
ok i have a b16a s1 tranny. stock motor. on a crx. i was wondering.
when does it realy hits. cause i was told that it was 4800 but i hear my vtec around 5200.. ?
Check your ECU, if it's a stock (non-modified or non-chipped) it's most likely hitting at 5200. I believe that is when the PR3 and PW0 kick in. Those are typically the most common OBD-0 VTEC ECUs. You should be able to hear it though. Just put the car into second and slam on it, so long as your tires arent making a ton of noise you should hear it just fine.... If you cant seem to hear it your filter in your vtec solenoid might be clogged.
If your VTEC is hitting weak (clogged solenoid filter or bad spark perhaps) you aren't going to feel it. As much as everyone tells you to wait for the feeling wait for teh sound. It's the sound that your going to notice before the feeling.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 »</TD></TR><TR><TD CLASS="quote">well yah,. i hear it. around 5200 hahahhahha and i watch my gas needle go down. hahahhahahahahahaha ok so its normal then .</TD></TR></TABLE>
wurd to that...
wurd to that...
He is using a pr3 ECU....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNDER PRESSURE »</TD></TR><TR><TD CLASS="quote">I hate the PR3 ecu I don't really hate it I just hate the fuel cut-off(governor).</TD></TR></TABLE>Get it chipped like I did
Only thing that sucks is that you have to get an aftermarket ignition system to get a rev limiter. That made me so nervous.
My PWO has a governor too, but I guess that's what keeps me from killing myself...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">
Not like I ever hit 100+ in my car anyway.. But my vtec come in at like EXACTLY 5000 unless I'm barely hitting the gas..
</TD></TR></TABLE>Not like I ever hit 100+ in my car anyway.. But my vtec come in at like EXACTLY 5000 unless I'm barely hitting the gas..
malo11
21
Dec 24, 2022 04:57 PM
phatnucca
32
Apr 14, 2012 08:54 PM
rollindelsol
11
Dec 9, 2006 04:53 PM
