VTEC Question? When should it turn on?
Old Jan 26, 2002 | 03:09 PM
vincent97gsr's Avatar
Default VTEC Question? When should it turn on?
My Vtec turns on and lets go at different points in the powerband. Usually at 5k you can hear it switch on, but sometimes it kicks on early and turns off late. Has anybody heard of anything like this before?
Old Jan 26, 2002 | 03:12 PM
Malice's Avatar
New User
Default Re: VTEC Question? When should it turn on? (vincent97gsr)
vtec engages at 4400rpms. the secondary butterflies open at about 5600rpms. alot of times people mistake the secondary openers to be the "vtec sound"
also, if your motor is not warmed up all the way, sometimes it kicks in late.
Old Jan 27, 2002 | 11:40 AM
Isaac's Avatar
New User
Default Re: VTEC Question? When should it turn on? (MaliceGSR)
Other way around, the Secondaries open up at 4400 in the Intake Manifold and then VTEC engages around 5600-6000 RPMS.
Old Jan 27, 2002 | 11:43 AM
hybrider's Avatar
Default Re: VTEC Question? When should it turn on? (98 GS-R)
isnt vtec crossover at 4,400rpm while the 2ndaris are at 5.5/6k rpm?
someone is misinformed.
Old Jan 27, 2002 | 11:46 AM
91DA9's Avatar
It all depends on the engine and whether or not you are using a different ECU.
If you have a STOCK B18C1 with STOCK ECU. Then VTEC will engage at WOT at 4400 and the secondary intake runners open at 6000 RPMs. It is very hard to hear the VTEC engage, the secondaries, however, are much louder.
Old Jan 27, 2002 | 11:51 AM
threatcon13's Avatar
New User
wrong...vtec engages at 4400 rpms and secondaries open up at 5800. if the temperature isnt right it wont engage.
Old Jan 27, 2002 | 12:27 PM
akhom's Avatar
Default Re: VTEC Question? When should it turn on? (turbo01gsr)
Once again.
VTEC is not set at any RPM.
It will engage as need. Lowest engagement point is 4400 rpm. (heavy load on motor, heavy throttle, enougt oil pressure, normal temp. and so on...
I have had VTEC engage as late as 5400 rpm. Down hill almost no throttle.
Scrondaries open at about 5700 rpm.
So there is nothing worng with your car.
Old Jan 28, 2002 | 09:05 PM
Isaac's Avatar
New User
Damn, I feel like an *** now. Sooo.....considering....I don't even know what I was going to ask.....*runs away flapping arms like a lil' ol' bitch* (Who wonders if the B-Word will be censored)
Isaac's Avatar
New User
Woo Hoo! Bitch! Umm....oops.
Old Jan 28, 2002 | 09:27 PM
Chris's Avatar
Old Jan 28, 2002 | 10:20 PM
Stock R's Avatar
Default Re: VTEC Question? When should it turn on? (Chris)
so that's how the vtec lobe works..... i could never figure out how.
Old Jan 28, 2002 | 10:55 PM
nfn15037's Avatar
Default Re: VTEC Question? When should it turn on? (Stock R)
Hah, gotta love Honda marine site
h4mza
Feb 22, 2013 10:13 AM
madblkscientist
Aug 14, 2009 09:00 PM
DXDOHCVTEC
Jul 29, 2004 10:34 PM
hman09
Feb 22, 2004 08:50 AM
unKnown
Dec 24, 2001 01:52 PM
