t3/t4 .63 a/r spooltimes
Old Feb 18, 2004 | 02:53 PM
Medek's Avatar
Default t3/t4 .63 a/r spooltimes
(t3/t4) when should i expect a .63 a/r housing to hit in the rpms range? and how long will it pull (rpm range) with a 50 trim compressor.. for a b18b1 w/ injectors & safc hack.. planning on boosting 7-9 psi
any differance using a straight t3?
Old Feb 18, 2004 | 09:25 PM
DownBoyDown's Avatar
Default Re: t3/t4 .63 a/r spooltimes (Medek)
Id also like to know!
Old Feb 18, 2004 | 10:05 PM
Silverbeast's Avatar
I would say on that motor, beginning spool around 2800-3400 and full boost by about 4500.
Stick with the t3.t4 design.
Old Feb 18, 2004 | 10:12 PM
intekragsr's Avatar
It helps to know the manifold design/maker, downpipe size, cat/nocat, exhaust, ebc/mbc or spring only?
When you say:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Medek &raquo;</TD></TR><TR><TD CLASS="quote">(t3/t4) when should i expect a .63 a/r housing to hit in the rpms range? </TD></TR></TABLE>
What do you mean hit? Hit 1psi? 7-9 psi? HP? Torque? A Cow?
Old Feb 19, 2004 | 02:34 AM
Adi Radoncic's Avatar
On Fire!
T3/T4 Pritty fast
T3 FAST
Old Feb 19, 2004 | 08:08 AM
99B16Si's Avatar
Default Re: t3/t4 .63 a/r spooltimes (newgsr)
yea there many variables that can increase/decrease spool time:
the exact size of the turbo
wastegate spring
manifold
intercooler size
piping design
boost controller settings.
i can say that my t3/t4e 60-1 stage 3 .63ar hits 7psi in 5th at 3700rpm and thats on a 9:1 b20vtec motor. 3rd gear takes a little longer(~4300rpm)
Old Feb 19, 2004 | 09:53 AM
OnePointFive's Avatar
overrated.
Default Re: t3/t4 .63 a/r spooltimes (99B16Si)
i'm running a 60 trim and i'm in full boost at about 4500.
Old Feb 19, 2004 | 10:17 AM
mike1114's Avatar
Default Re: t3/t4 .63 a/r spooltimes (OnePointFive)
I know its not same setup as yours but I got B18C with T3/T4 .60/.63 57 trim.
Spool starts around 3200 and full boost by 4500 rpms @ 10psi. 2.5" piping.
CivicVX94
Dec 6, 2005 07:28 PM
elpiar
Sep 6, 2005 08:01 AM
BoOsTiN Dc2
Jun 9, 2004 11:24 PM
highschooler
Feb 22, 2004 05:45 PM
BoosterChair
Apr 13, 2003 09:18 PM
