questions about turbos...
Old Feb 18, 2004 | 12:38 PM
t25hatch's Avatar
Default questions about turbos...
Im in the process in doing some research about building boost for a turboed d16z6, and beginning to be confused. What are some easy and cheap steps I can take in achieving around 12-15 lbs. of boost? Port and Polish head? wastegate spring? thanks for the input, much appriciation??
Old Feb 18, 2004 | 12:45 PM
rusteds2k's Avatar
Default Re: questions about turbos... (t25hatch)
Your best bet is to search on Honda-tech. Alot of info you'll need will be found Here on H-T...
Btw: you're lucky i'm nice. Some of the guys here will bitch at you for this.
Old Feb 18, 2004 | 12:58 PM
zseeanz's Avatar
damn and I was just about to flizzzame. Yeah man do a search. You can get 20 psi w/o a port and polish. Just start simple with a junkyard turbo. If you get a kit, make sure you have room to uprade later. But start off small if you're new to turbo. You'll be happy if you do it right. But if you know you're gonna boost 12-15, I'd suggest investing in some forged robs and pistons before you ever put your 1st lb of boost though your motor. That way, if you get a kit and you have it up to say, 9psi like me. You can up it to 12-15 cause you already have a solid block. Make sure you tuned the hell out of it at that high of boost.
Old Feb 18, 2004 | 01:03 PM
t25hatch's Avatar
haha.. thanks, im new if it isn't too obvious
Old Feb 18, 2004 | 01:06 PM
zseeanz's Avatar
remember, start small. It's a d16 right? Try going to http://htt://www.turbod16.com they're all d series guys over there.
Old Feb 18, 2004 | 01:11 PM
t25hatch's Avatar
i have a d16 with a stock greddy turbo kit... im just looking for a little more boost...
Old Feb 18, 2004 | 01:13 PM
zseeanz's Avatar
what are you boosting now?
Old Feb 18, 2004 | 01:14 PM
zseeanz's Avatar
get a mbc, bigger injerctors, and tune.
rustydusty1717
Jun 23, 2008 05:27 PM
BlUAc
May 20, 2006 09:43 AM
91accordex16
Jun 23, 2005 02:51 AM
bodea_florian
Aug 25, 2004 06:54 PM
Pengo
Jun 24, 2002 10:56 PM
