Torque spec for axle nut?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 »</TD></TR><TR><TD CLASS="quote">134lbs. </TD></TR></TABLE>
I need to un-stake and re-torque mine... dammit, forgot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Incognito »</TD></TR><TR><TD CLASS="quote">Is it really necessary to torque the axle nut? We usually just hit it with the gun, or use the breaker bar till it doesn't go anymore.</TD></TR></TABLE>
The one time that over torquing/gorilla locking the nut is a good thing.
Yes it is very important it is torqued down right....the hub bearing takes a role in that as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 599 »</TD></TR><TR><TD CLASS="quote">134 is correct. but i did 140 since it took like 400 to get it off
I think the same holds true for the crank pulley bolt. That bitch seems like it seizes on there and takes 500lbs to get off. Then when you go to put it back on, it doesnt feel right bc it seems like you are hardly putting it on tight compared to how tight it was when you took it off.
</TD></TR></TABLE>I think the same holds true for the crank pulley bolt. That bitch seems like it seizes on there and takes 500lbs to get off. Then when you go to put it back on, it doesnt feel right bc it seems like you are hardly putting it on tight compared to how tight it was when you took it off.
I broke 2 craftsman sockets trying to remove both of those with my 3 foot breaker bar and a fat guy on the end of it
I think the same holds true for the crank pulley bolt. That bitch seems like it seizes on there and takes 500lbs to get off. Then when you go to put it back on, it doesnt feel right bc it seems like you are hardly putting it on tight compared to how tight it was when you took it off. </TD></TR></TABLE>
tsdenny
Sep 23, 2005 06:14 PM
