14.8 et, 94 mph 2.3 60 FT, its this a good time??
hi i live in Panama, sea level , lots of humidity, heat and the race track its not that good
i have a 97 civic EX with a GSR complete swap OBD1 , i/h/e toda A cams, bored tb.
no lsd , old clutch RA1 tires(205-50-15 with 18 psi of air)
can i get a 14.1 with a LSD, ITR FD, new clutch , flywheel ???
or will i need more
or will i need more
alright time...i ran 14.2 @96 mph in my 92 si hatch full interior . 95 gsr swap no lsd with intake and universal exhuast on street tires.
Munkyw3rkz.webs.com
you should be running a lot better!!!
depending on how much your car weighs...i would say your se up looks like a high 13 set up
As you said, get a clutch, toss on some slicks and you should be set... Those EJ chassis' are a definately more to move than an EH... A friend of mine that I did a GSR/EJ6 (so a little lighter) swap for a few years back runs consistent 13.40's with a CTR IN cam, clutch, and slicks so I see no reason why say 13.70's aren't attainable... Good Luck
94 mph is good for mid to low 14's already with just better 60' foot times.
If you want even better get some bfgoodridge street slicks, I've heard great things from them, but be careful about your use since they have fast treadwear.
Yes a 14.1 is attainable with those extra goodies that you stated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bulori »</TD></TR><TR><TD CLASS="quote">hi i live in Panama, sea level , lots of humidity, heat and the race track its not that good
or will i need more
Hey...this sounds like my similar setup a couple years back. The only difference I had ITR Intake Cam, RPS Clutch and Nitto's 555R, alo running a stock OBD1 ECU.
My best on street tires was 14.2 (forgot the mph), but with some small 20" slicks, I ran (actually Terry- Incognito is his HT name) ran a 13.80@98.
or will i need more
i would say a lil bit more beefy clutch with your plans i would say a stage 2? iam not sure to be honest thats my guess considering the mod's u plan. i would say stage 3 race if u to do any sort of FI. anybody else opinion?
anyone knows the SPEC brand
nipponpower offer them
its made of kevlar not bad and has a good price here is the link
http://www.nipponpower.com/dri....html
Declectic
10
Feb 6, 2004 08:24 PM
