resetting ECU. does this reset igntion timing too?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAD ITR 55 »</TD></TR><TR><TD CLASS="quote">no</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dax-es »</TD></TR><TR><TD CLASS="quote">That's why you should just pull the fuse instead of disconnecting the battery. It beats redoing your presets.</TD></TR></TABLE>
Which fuse is this, and where is it located? I'd like to reset mine to get rid of the engine light.
When I had tried reseting check engine lights using the fuse pulling method the light would not reset. I had to pull the battery. This is on a GSR though. Shouldn't be any different but if yours does not reset then you know to pull the battery.
You'll have to pull the backup fuse next to the F/I fuse. 30 seconds is enough. That is what the service manual says.
the timing will take sometime to return to their original setting. the car actually feel weaker after the reset and return to normal after about a tank full of driving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 »</TD></TR><TR><TD CLASS="quote">You'll have to pull the backup fuse next to the F/I fuse. 30 seconds is enough. That is what the service manual says.</TD></TR></TABLE>
I stand corrected. That is indeed what the service manual says. Too bad it also kills the radio, but at least it's still easier than disconnecting the battery. Although C-Speed have it listed as the FI E/M fuse.
<U>http://www.c-speedracing.com/faq/02.php</U>
or get a stereo with it on offline power source or HDD based memory
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>Why HDD? Flash mem is much easier and smaller.
Drinker
